> Speedomtere hole size, what is it?
keske968
post Apr 16 2010, 10:13 AM
I'm picking up a 914 in the next week and want to put in a differnt speedometer (GPS run) and am curious as to the hole size for the 914 speedometer. Just want to make sure the one I have my eye on will fit. Did a search and didn't have anything pop up.
Thanks for your time... I know its a stupid trivial question but there are two differnt options i can get. One requires a 3.875" hole and the other requires a 3.375"
Would one of these work without too much modification?
Linky
http://www.speedhut.com/gauge_products-gau...dometer_GPS.htm
Replies(1 - 3)
Smitty911
post Apr 16 2010, 10:18 AM
Can't help you on the hole diameter.
Pretty nice find though, I was wondering about the Calibration of the unit if it is cal'd or not. I didn't see anything on thier site.
DBCooper
post Apr 16 2010, 11:53 AM
14's in the 13's with ATTITUDE
I don't know about those, but I'd assume the 4" electronic programmable VDO in mine is the same size. If I recall the dash hole was 100mm, or just under 4" so I assumed it would fit or maybe even require a little trimming. I should have looked a little more closely because it didn't. The whole speedo went right through the hole in the dash and had to have a little flat bezel adapter made to fit and stay in. Wish I had one to measure for you though, I've been burned before by relying on my memory.
keske968
post Apr 16 2010, 09:43 PM
Thanks for the info. I think I'll get one once i pick up the car and can measure. Just wanted to get a jump on it.
- Lo-Fi Version Time is now: 4th January 2025 - 07:49 PM
