Transmission Ground Strap |
dnoce73914 |
Apr 20 2010, 12:42 PM
Newbie Group: Members Posts: 2 Joined: 20-April 10 From: San Marcos, CA Member No.: 11,638 Region Association: Southern California |
Does anyone have a picture of the transmission ground strap installed? I am having a hard time determining where the contact points are.
dlee6204 |
Apr 20 2010, 12:49 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
SirAndy |
Apr 20 2010, 12:52 PM
Resident German Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Does anyone have a picture of the transmission ground strap installed? I am having a hard time determining where the contact points are. No pic right now (i'm at work) but one end goes to one of the bolts on the end cover and the other to a stud on the bottom of the trunk floor. The stud is above the center of the tranny towards the rear end cover. The strap is pretty short, 5" maybe ... (IMG:style_emoticons/default/shades.gif) Andy PS: (IMG:style_emoticons/default/welcome.png) |
dnoce73914 |
Apr 20 2010, 01:02 PM
You can see where it is bolted to the underside of the trunk floor in this picture. Upper right corner of the picture. (ignore the relay) Thanks you all for the reply, so fast too! I am new to the site and loving it already. i have a 1973 1.7 and am finally getting back to working on it. I have installed the Bosch hot start kit to no avail. I know the starter is good so I recently discovered that i couldnt discover a ground strap. Going to try this tonight. Thanks again. |
biosurfer1 |
Apr 20 2010, 01:15 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Good idea...not having that ground strap can cause some weird things to happen...one less thing to wonder about if its installed correctly.
underthetire |
Apr 20 2010, 01:34 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
You can see where it is bolted to the underside of the trunk floor in this picture. Upper right corner of the picture. (ignore the relay) You need to clean that (IMG:style_emoticons/default/poke.gif) |
dlee6204 |
Apr 20 2010, 02:30 PM
QUOTE You need to clean that I KNEW someone was going to say that. That picture was taken when I first got my car. You better believe that thing is clean now. (IMG:style_emoticons/default/whip[1].gif) |
Eric_Shea |
Apr 20 2010, 03:34 PM
PMB Performance Group: Admin Posts: 19,280 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I went crazy with mine and cleaned it and taped it off before I shot the Wurth. This has to be a good ground:
(IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1110-1271799276.1.jpg) You can see the stud in relation to the tranny mounts better here: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1110-1271799277.2.jpg) |
Lo-Fi Version | Time is now: 2nd July 2024 - 08:14 PM |
