> Another test drive today...., Now my left side lights are not working.
montoya 73 2.0
post May 9 2010, 12:14 AM
Lack of consideration to others, and Selfish!
Headlights work, fog lights work. The brake lights and the blinkers work on both sides but no running indicators on left side (drivers) front or rear? What say you?
Replies(1 - 3)
Mike Bellis
post May 9 2010, 12:32 AM
Resident Electrician
wiggle the bulbs. replaced mine today with new bulbs and they stopped working. A little wiggle and they came back. Also check and clean the ground behind the headlight bucket.
montoya 73 2.0
post May 9 2010, 07:57 PM
Well, I tried the wiggle and checking the connections to the fuse box and nothing. Ground wires are fine. I had installed the Engman fuse box awhile back with the "smart" fuses, Well the fuses aren't so smart. I thought I should check the fuses but none were lit up so I checked anyways and yep the left side fuse was blown. I thought those smart fuses were supposed to light up when they blow?
dr914@autoatlanta.com
post May 10 2010, 12:46 PM
QUOTE(montoya 73 2.0 @ May 8 2010, 11:14 PM) *
we say loose fuse.
- Lo-Fi Version Time is now: 22nd December 2024 - 06:21 AM
