Will stock distributor work with my new weber 40's |
RMally |
May 12 2010, 05:21 PM
Newbie Group: Members Posts: 24 Joined: 25-October 09 From: Tennessee Member No.: 10,977 Region Association: South East States |
I'm hoping to get the carbs on this week, but wanted to know if the stock distributor is ok to use.
It seems in the past I remember reading something about changing the distributor but wasn't 100% sure. I currently do not have EI, will that matter as well. Thanks, |
SLITS |
May 12 2010, 05:26 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Supposedly an 050 or stock 1.8L distributor has a better advance curve for carbs. You didn't say what you had anyway.
r_towle |
May 12 2010, 05:27 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yes it will work.
If you have a choice, the Ljet distributor is a better choice. Either one has a better advance curve than an 009. If you are at a VW swap meet and happen to find an 050 distributor, those work pretty well also. rich |
RMally |
May 12 2010, 08:45 PM
Thanks, I did forget to say it's a 1974 model 1.8
r_towle |
May 12 2010, 09:25 PM
your all set.
If you hook up the vacuum advance to the little port on one of the webers (both if you want to do it right) then you will enjoy it. Go to Aircooled.net to read up on running the vacuum advance with the webers...he has a decent few articles about the distributor. Rich |
ClayPerrine |
May 12 2010, 09:26 PM
Life's been good to me so far..... Group: Admin Posts: 15,965 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Then use the stock distributor.
And float test the 009. If you throw it in the lake and it floats, use it. |
70_914 |
May 13 2010, 11:14 AM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Did you change your cam to one more meant for carburetors? If your cam is too big it won't make any vacuum and your vacuum advance distributor will be worthless....
That is the way I build VW motors.... (IMG:style_emoticons/default/biggrin.gif) |
nsr-jamie |
May 14 2010, 08:20 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Not to hi-jack here but how do you tell the difference between an 009 and the 050? Is it written on there somewhere?
Root_Werks |
May 14 2010, 08:31 AM
Village Idiot Group: Members Posts: 8,525 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Not to hi-jack here but how do you tell the difference between an 009 and the 050? Is it written on there somewhere? Usually says 009 or 050 in the part number on the side of the dist. There are also a couple of dizzy's that have worked well on carb'd 914-4's from 356's or 912's. I think they are the 010's? Can't remember. But they are a dist that is designed for carbs and cams for carbs etc. |
Lo-Fi Version | Time is now: 4th January 2025 - 11:04 PM |
