> Fog light removal, wiring at least
echocanyons
post Apr 3 2004, 07:09 PM
I need to remove the fog lights on my car but I cant seem to figure out how to get the wiring off of the light.
Im sure the lens is removable somehow to change the bulb but I dont understand how to do this
any ideas?
Replies(1 - 5)
415PB
post Apr 3 2004, 08:42 PM
Remove the foglight with bracket, via the large allen bolt. On the bottom of the foglight bezel is a screw. Unsrew this and remove the tab that holds the bezel in place. Remove the bezel and now you will see how the wires are connected. 12V is simply held in by a screw (unscrew this screw) and ground just plugs into a male connector.
echocanyons
post Apr 3 2004, 08:50 PM
I unmounted it and removed the screw but couldnt figure it out how to remove the bezel.
There is a hole in the bottom of the bezel do you push this over to release the bezel?
415PB
post Apr 3 2004, 10:00 PM
There is supposed to be a small tab that is screwed into that hole. If there isn't one, then you are missing yours. Gently pry the bezel from the lamp housing and and look inside. Hope this helps.
echocanyons
post Apr 3 2004, 11:11 PM
I removed the tab but it didnt budge maybe it was stuck on with grime and time.
Ill give it another shot tomorrow
Thanks!
echocanyons
post Apr 4 2004, 05:22 PM
got the housings apart they were just stuck by grime.
I had to cut the wiring cuz it was soldered to the light.
Thanks for the tips
- Lo-Fi Version Time is now: 26th September 2024 - 05:31 PM
