Shift linkage, Trying to refresh connections. |
damnfiknow |
Jun 27 2010, 09:03 PM
Member Group: Members Posts: 77 Joined: 25-October 09 From: Texas Member No.: 10,980 Region Association: None |
Going thru replacing the busings etc of shift linkage on 75. Installed firewall, shift rod, ball cup bushings. Have a new pilot bearing and trying to get up the nerve to put it in. Sounds easy in the Haynes book.
When ordering the parts , I just checked all I saw in the bushings section. Received one IDed as Pivot Bushing. Where does it go? Only pivot I can think of is where the release bearing lever fits to the housing. |
GeorgeRud |
Jun 27 2010, 09:37 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
That's where it goes. Also, check your motor and transmission mounts as they also affect the shifting.
Good luck on your project. |
jaxdream |
Jun 27 2010, 09:51 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
If ya gonna pull the tranny to do a pilot bearing , might as well do the flywheel seals and the trans input shaft seals , and that piviot bushing also . When you're done , you'll know that all is good for a long time, oh yeah might as well do the release bearing while in there , and there is the ..................
(IMG:style_emoticons/default/stirthepot.gif) Jack / Jaxdream |
xperu |
Jun 28 2010, 06:17 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Going thru replacing the busings etc of shift linkage on 75. Installed firewall, shift rod, ball cup bushings. Have a new pilot bearing and trying to get up the nerve to put it in. Sounds easy in the Haynes book. When ordering the parts , I just checked all I saw in the bushings section. Received one IDed as Pivot Bushing. Where does it go? Only pivot I can think of is where the release bearing lever fits to the housing. I just replaced the bushings in the coupling at the firewall where the where the shift rods connect along with the tapper screw. I had forgotten about it when changing all my other bushings and was caught by surprised when they fell apart into small pieces after 35 yrs. and I had no shifting whatsoever. I bought everything from AutoAtlanta. What part of Texas do you live? I'm in League City, south of Houston. Mike |
Lo-Fi Version | Time is now: 26th September 2024 - 05:27 PM |
