mipstien |
Member ![]() ![]() Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States ![]() |
i couldn't find any information on how to adjust or replace the side mirror and i didn't wanna just start unscrewing it incase those screws had bolts on the back and i lost those in the door panel when they fell.
do you just unscrew or do you have to take the panel off? mirror doesn't adjust because its rusted or too tight. |
plas76targa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region ![]() |
you can unscrew the screws. the 'nuts' they thread into are welded into the fender. (assuming you have stock mirrors)
once the mirror is removed turn it over and look down the 'barrel' there is a nut inside. remove that and the two half barrells, clean them all up with cleaner and perhaps a 3m pad. lubricate with a tiny amount of white lithium grease, reassemble and tighten nut just enough to allow adjustment moves. Re-install on door. my $.02 |
mipstien |
perfect thanks ill take care of it now (IMG:style_emoticons/default/smile.gif)
plas76targa |
one last note - you may find you'll need a very thin walled socket to reach that nut in the mirror. and the nut is odd size like 8mm 0r 9mm.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I recommend putting some PB Blaster on the nut and letting it soak a little bit. If you get in a hurry, the pot metal has been known to break leaving the mirror useless. You can also take the plastic trim(AA has new ones if you break it)off the mirror and remove the glass. Remove plastic liner and spray the pivot nut.
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,884 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
I recommend putting some PB Blaster on the nut and letting it soak a little bit. If you get in a hurry, the pot metal has been known to break leaving the mirror useless. You can also take the plastic trim(AA has new ones if you break it)off the mirror and remove the glass. Remove plastic liner and spray the pivot nut. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Well since everybody already answered your Q -
... then when you're done, add one of these - http://www.automotion.com/product.asp?pf%5...;dept%5Fid=4077 (IMG:style_emoticons/default/biggrin.gif) |
windforfun |
Well since everybody already answered your Q - ... then when you're done, add one of these - http://www.automotion.com/product.asp?pf%5...;dept%5Fid=4077 (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
johannes |
Club Porsche 914 France President ![]() ![]() ![]() ![]() Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France ![]() |
There is a thread about that in the classics (pictures on page 2)
http://www.914world.com/bbs2/index.php?showtopic=42362 ... |
mipstien |
i was concerned about the pictures too much. its pretty straight forward but even after getting mine off and pulled the bolt and spring out it was really tough to do anything with it. apparently over time and vibration the spring had pushed that tightening 'cone' piece up really far and made it hard to get it out. it did eventually come out and i understand now how the mechanism works. simple design.
so anyways after pulling it is it better to tighten it down or make it loose so it can be moved a little. my g/f and i will both drive this car and she needs the seat quite a bit up and i need it all the way back. im sure i can manage if it moves a little while driving both of my motorcycle mirrors do also. |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
After cleaning it, I wouldn't leave it loose, otherwise it might adjust itself on you... reassemble and see if it works OK...
Lo-Fi Version | Time is now: 25th June 2024 - 07:56 PM |
