> Head Exhaust Stud Question, what is the correct size?
76-914
post Jul 24 2010, 11:56 AM
First, I have a stripped hole where the exhaust stud threads into the head. It's a stock 75 2.0 . The PET manual shows #014 397 9, which is AM8 x 56 (what's the "AM" stand for?) qty "8"ea. It also lists #014 684 1, which is CM9 AX MB x 56 (what do "CM", "AX" and "MB" stand for?) qty "X"ea. ( X ???? ) Are there possibly two different diameter studs that were used on the 2.0? The AM 8 is 8mm, right? If so, is the CM9 a 9mm?
Secondly, is there any reason I should not drill and tap/heli coil the head in place from beneath the car. It's looks do-able as hell but thought I would ask here, first. Thx
Replies(1 - 4)
dr914@autoatlanta.com
post Jul 24 2010, 01:03 PM
QUOTE(76-914 @ Jul 24 2010, 10:56 AM) *
I would certainly install a 9/8 mm stud first before tapping any more oversize. The 9mm (still 8 on the bottom) is a stud installed on the 1.8 models. If everything else fails you can install as large as a 10/8x56 stud.
post Jul 24 2010, 02:56 PM
The current studs do step down in size. One end is 8mm x 1.25 and the other end must be 9mm because it's too loose in a 10mm die. However, I do have 2.0 heads so maybe they were changed out before?? Anyway, the old hole is pretty smooth and there are only 2-3 threads remaining. Anyone here sell the 10 x 8 56 stud that George mentioned or is it dealer item. Also, what is the correct number/letter drill bit for a 10mm tap?
avidfanjpl
post Jul 24 2010, 03:27 PM
914 Hemophiliac
AA has the 10mm to 8mm stud in their catalog. I have seen them. He has 8X8 - 9X8 and 10X8. Download the pdf from their site to see them and call.
Check with AA on Monday before buying the right tap and heli coil.
John
underthetire
post Jul 24 2010, 04:59 PM
http://www.mcmaster.com/#step-studs/=83t12j
And you can get taps, drills, whatever else you need. I always get stuff in 24 hours from them.
- Lo-Fi Version Time is now: 4th January 2025 - 10:02 PM
