bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Yes, how does the horn go honk from the steering wheel Horn Button (butterfly part)? The parts diagrams don't show how it works
On my steering wheel, the single wire comes up via a hole in the steering wheel, and plugs into the metal plate on the back of the horn button, except it doesn't go honk. I can ground the wire and the horns work fine. The 2 parts I'm missing from the parts page are the spring loaded contact pin and the horn button rubber center support. If I need the pin contact, how does the wire get to the horn button plug. Drawings...Pictures ...Please. Thanks Attached image(s) ![]() ![]() ![]() ![]() |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
IIRC both the Haynes & Factory Manuals & maybe 700 tech tips & others show it in pix &/or descriptions.
... you do need both the pin & rubber cup, which is probably why a cheapo DAPO disconnected it not having the parts - is my guess. Sierra Madre Collection sells both the pin & cup separately, as well as a horn rebuild kit with them & a few other parts for the 914s. AA, PP/Automation, Pelican, TCsGarage, etc., etc. also sell the pin & cup separately, but the cost for both may equal the SMC kit. |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
The contact pin is only for 70/71 cars. We all have the rubber cup "spring".
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
If you fix it and it goes "honk" "honk", you probably have an after market horn. On the other hand, if it goes "beep" "beep", or... you know... something like that, you will then know that you have a stock horn. You don't find info like this in any damn Haynes manual.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
This.....
![]() Touches that.... ![]() When you push the button. |
bandjoey |
So you want me to buy a book and read??? (IMG:style_emoticons/default/biggrin.gif) The unspoken in Haynes is that the
wire replaces the pin in the 73 and the rubber cup is what holds them apart. And real Texans never say beep beep. (IMG:style_emoticons/default/flag.gif) Thanks |
Lo-Fi Version | Time is now: 26th June 2024 - 06:16 AM |
