brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I'm looking for a used, but useable sandwhich adapter
I want to add a cooler to a beater I'll just go under the rear trunk also if anyone has an old set up (a cooler with fan), lines, and parts that didn't have a motor die and deposit metal... I'm interested in more than just the sandwich adapter if you have it. please pm or email in case I don't see this thread. brant |
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
brant |
thats a great price.
but it looks "thicker" than the other ones I've seen I'd hate for the oil filter to be an extra inch or two lower. It seems the normal adapters cause the filter to be low enough already.. have you used this one? how thick is it? brant |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
That adapter on Jegs is made by the company I work for. The adapter is 1-5/8 inches thick. If you want one I can sell you one for $20.
Bruce |
brant |
That adapter on Jegs is made by the company I work for. The adapter is 1-5/8 inches thick. If you want one I can sell you one for $20. Bruce Bruce, that is about the nices offer ever I'll go measure how much extra height I can get away with (the PO really lowered this car a ton) do the ones you manufacture have a thermostat? brant |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
the new Mahle filters are shorter and that makes up for the adapter.
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
beware of used coolers, speically the plate type coolers, they can trap metal chunks from failing motors. only to come out later and wreck you motor. be sure the cooler you buy comes out of a good car for sure. also rinse it at least three times with paint thinner. if any signs of metal contaminations, toss it out.
it is very very hard to clean them effectivly (unless it is the tube type cooler which can be cleaned easy) good luck on you search. PS empi sells new coolers with or with out electric fans. I got a large 96 plate cooler with a 9 inch fan for $170 at Bugformance of san jose. that is a typical empi price. you can probably use the 72 plate cooler in teh 914 as it might fit better. the 96 plate goes in my bus have fun |
brant |
cooler on order through summit (similar to empi)
plate also on order thanks to Bruce!!!!! hopefully I'll be able to install in a week or so and beat the summer heat! thanks to everyone, and especially to Bruce! brant |
Lo-Fi Version | Time is now: 20th June 2024 - 06:05 AM |
