Eddie914 |
Unregistered ![]() |
New Zimmerman front brake rotors were just installed on my 914/6 3.2 (conversion) DE car. It is using 911SC brakes front and rear with Porterfield R4 race pads.
The old rotors had developed a bad vibration and were worn beyond spec after 5 years of track use, so no chance of having them turned (again). Should the rotors be run in with new pads or old (60%) pads. I will be attending a DE day on friday and the new pads need to be heat cycled before the event. I do not think it is advisable to heat cycle the new pads on brand new rotors. Your opinions, experiences or expert advise is appreciated. Thanks in advance. Eddie |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Use the old pads first. It always works better.
Eddie914 |
How long does it take to "bed in"/"break in" the new rotors?
Track day on friday. There is a track day tomorow but I CAN NOT make the morning (VERY important business meeting). Thanks, Eddie |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE Use the old pads first. It always works better. Nada... use your new pads as "both" need to be bedded in/seasoned properly "together". http://www.pmbperformance.com/page/page/1492423.htm |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
QUOTE Use the old pads first. It always works better. Nada... use your new pads as "both" need to be bedded in/seasoned properly "together". http://www.pmbperformance.com/page/page/1492423.htm (IMG:style_emoticons/default/agree.gif) When you buy a new car does it come with used pads??? |
Lo-Fi Version | Time is now: 25th June 2024 - 08:10 PM |
