Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
OK, I have a 3.0 with Webers in my car; it has not run for 7 months. I want to start it so I can shoot a video of the engine running so I can sell the engine and transaxle. I figure people would prefer to see and hear it run.
1. The oil tank, with the dispstick, shows no oil. Is that normal after sitting for 7 months. I know to check the oil accurately the engine needs to be warm and idling, but I never checked one to see what showed, if anything, on the dipstick when the car has sat for an extended period of time. 2. Should I pull the plugs and squirt something in the cylinders before trying to start it? Oh, if you know someone looking for a 3.0 with Webers and a transaxle, (not an original six transaxle or I would be keeping it) let them know this is available. By the way the car ran fine when I bought it 7 months ago. Started right up and drove with no smoke at all. Thanks. |
jpnovak |
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region ![]() |
6 months is not that long.
Pull the ignition lead, crank engine to build oil pressure. REconnect ignition. then start it up. I would be more concerned with the old gas unless there was a stabilizer used. It will probably run, spit and sputter on the old gas. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Oil will drain back into the crankcase, but I've always been told that you should see oil on the very end of the dipstick before starting.
If I was a potential customer I'd want a leakdown test. |
Cairo94507 |
Thanks for the input; I may have a leak down test done. Thanks.
Lo-Fi Version | Time is now: 26th June 2024 - 06:09 AM |
