Fuel pump seals for 3 port pump, who sells them? |
slu234 |
Dec 15 2010, 08:16 AM
Member Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region |
I have a `70 1.7L D-jet with stock 3-port pump. The pump runs strong but the seals are shot, specifically the rubber on the spring regulated needle valve.
Would like to keep the pump but just need new seals. Does anyone sell a kit or repair parts for these? Brian |
tod914 |
Dec 15 2010, 09:15 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Fuel injection corp in Ca rebuilds them. Maybe they can sell you seals.
slu234 |
Dec 15 2010, 10:40 AM
realred914 |
Dec 15 2010, 01:29 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
these pumps if allowed to dry out after gasoline expose can have the seals shrink and hence leak. It might be more of a probelm with todays gasoline. You might inquire if the new rubber you get is "modern fuel proof" to insure a long life of the pump.
Lennies914 |
Dec 15 2010, 07:37 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Fuel injection corp in Ca rebuilds them. Maybe they can sell you seals. Thanks. I'll give them a call and report back. Brian (IMG:style_emoticons/default/popcorn[1].gif) That would be a good find if they will sell the parts. |
slu234 |
Dec 17 2010, 08:54 PM
I sent an email to FI Corp. No response yet.
I have found a few places that make "grommet bumpers". If I can find a place that has a mold the same size as the fuel pump poppet end I'll try to get a quote for a bunch of them made of the correct material. Found some Viton o-rings the right size. Easy find at the hardware store. I'll post back when I find the right poppet (check valve) end. Brian |
Lo-Fi Version | Time is now: 24th September 2024 - 01:16 PM |
