stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I have been asking everywhere and cant find one.
Do I just buy the closest tubing I can get from mcmaster carr and hope it fits? I am guessing metric OD?? Stu |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Everywhere is NOT automobile atlanta (I guess that that is the general consensus here at the world site anyway!)
Plenty in stock AND we have beautiful cad plated dipsticks as well for you concours fruits like George, Steve, Tod, and Pat (anyone else want to join this exclusive group? I have been asking everywhere and cant find one. Do I just buy the closest tubing I can get from mcmaster carr and hope it fits? I am guessing metric OD?? Stu |
smg914 |
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,965 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None ![]() ![]() |
stugray |
George,
I posted a request for quote for a set of endplay shims and a dipstick tube to the AA website, but I have not gotten a response. (stugray@q.com) I want to order the tube ASAP as I plan on reassembling the engine next weekend. Let me know the cost & I will place the order (as long as it is reasonable) I was going to order two engine mounts from AA, but the cost is $45 EACH. Another site I found has them for $30 for a pair (new Porsche parts). ( AT PP, they are $125 each :-0 ) smg914, Who is Dave C.? Also - what is the name of that machine shop in L.A. that specializes in VWs? I had them line bore my ghia case 20 years ago, and they replaced the dipstick tube for free. I know, there are a TON of machine shops in LA, but I see the name of this particular one mentioned on this forum a lot....just cant remember. Stu |
different mounts. The 45 each are the early the 30 per pair are the late. the 125 are the factory. Our salesmen should be on the ball surprised that they have not answered you but 'tis the season, and they are sizing shirts for our lady gift buyers and hating it!
George, I posted a request for quote for a set of endplay shims and a dipstick tube to the AA website, but I have not gotten a response. (stugray@q.com) I want to order the tube ASAP as I plan on reassembling the engine next weekend. Let me know the cost & I will place the order (as long as it is reasonable) I was going to order two engine mounts from AA, but the cost is $45 EACH. Another site I found has them for $30 for a pair (new Porsche parts). ( AT PP, they are $125 each :-0 ) smg914, Who is Dave C.? Also - what is the name of that machine shop in L.A. that specializes in VWs? I had them line bore my ghia case 20 years ago, and they replaced the dipstick tube for free. I know, there are a TON of machine shops in LA, but I see the name of this particular one mentioned on this forum a lot....just cant remember. Stu |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
okok, this is about finding a dipstik not being a dipstik. (IMG:style_emoticons/default/lol-2.gif)
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Um.... dipstick TUBE! Go to your FLAPS and get some brake line. Cut to length, flare the end a bit to get a tight fit, and tap it into place. Works great and is indistinguishable from the OE except to the most astute of inspectors.
stugray |
Here is the response from AA:
"If your type 4 case is missing the dipstick tube, you will either have to go without a dipstick and plug the hole, or find a different case. The cases are pressed in from the factory to a specific height and it cannot be replicated easily. The machine work alone to try to press in another dipstick tube would be in the hundreds of dollars." I am pretty sure that when I had my Ghia case align-bored, I watched the machinist pull out the old broken tube with vice grips, and tap in a brand new one with a mallet. I have a hard time believing that it requires machining to fix this. The response from aircooledtechnology was: "You have a few ways to remove. 1)heat the case around the tube with torch(carefully!) and grip with vice-grips and wiggle out. 2)Cut it off flush with case and drive through with a drift or punch. 3)Drill it out." I find that to be a little more believable. McMark, Do you have a dimension? I am guessing that the tube is metric, but a brake line is probably close enough to make it work.... I guess if it is too small, a little JB weld could help ;-) The tube isnt completely broken off. It is bent over & cracked. I guess I can try to tig weld it before ripping it out. Stu |
http://www.autoatlanta.com/detail.php?Part...ial_number=9596
Here is the response from AA: "If your type 4 case is missing the dipstick tube, you will either have to go without a dipstick and plug the hole, or find a different case. The cases are pressed in from the factory to a specific height and it cannot be replicated easily. The machine work alone to try to press in another dipstick tube would be in the hundreds of dollars." I am pretty sure that when I had my Ghia case align-bored, I watched the machinist pull out the old broken tube with vice grips, and tap in a brand new one with a mallet. I have a hard time believing that it requires machining to fix this. The response from aircooledtechnology was: "You have a few ways to remove. 1)heat the case around the tube with torch(carefully!) and grip with vice-grips and wiggle out. 2)Cut it off flush with case and drive through with a drift or punch. 3)Drill it out." I find that to be a little more believable. McMark, Do you have a dimension? I am guessing that the tube is metric, but a brake line is probably close enough to make it work.... I guess if it is too small, a little JB weld could help ;-) The tube isnt completely broken off. It is bent over & cracked. I guess I can try to tig weld it before ripping it out. Stu |
According to Rich our sales manager: He emailed us on Friday night, afterhours. We answered him this morning.
McMark |
QUOTE McMark, Do you have a dimension? I am guessing that the tube is metric, but a brake line is probably close enough to make it work.... I guess if it is too small, a little JB weld could help ;-) The tube isnt completely broken off. It is bent over & cracked. I guess I can try to tig weld it before ripping it out. Stu You need 5/16 brake line (I used NAPA #813-5466). Break off the old dipstick and carefully grind it flush with the case. Drill the hole out with a 5/16" drill bit. Scribe a line on the replacement 6" from the top. That is the 'case line'. Cut off about 1" past the line. Test fit the new tube in the case. You want a snug fit. If the hole is too small, carefully drill is SLIGHTLY larger. If the hole is too big, you can flare the tube slightly. Using Loctite Green or JB Weld isn't a bad idea either. Just make sure you have 6" from the top of the tube to the case. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
I just recently had the same problem. My dipstick broke off just level with the engine tin. The 5/16 brake line works great. I had to reem it out a bit to fit. I used about a 3 inch length and tapped it on to the ramaining housing and then inserted the broken off piece of housing and tapped it on as well. The distance from the surface of the engine tin and the top of the stick housing is about 3 3/8 inches.
Attached thumbnail(s) ![]() ![]() |
McMark |
The distance from the surface of the engine tin and the top of the stick housing is about 3 3/8 inches. I added emphasis, so nobody thinks we disagree. (IMG:style_emoticons/default/grouphug.gif) |
Elliot Cannon |
The distance from the surface of the engine tin and the top of the stick housing is about 3 3/8 inches. I added emphasis, so nobody thinks we disagree. (IMG:style_emoticons/default/grouphug.gif) Hey! Get off the computer and get back to work. (IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:59 PM |
