F/S: '73 Fuel Injection System Parts, Parts for '73 1.7L 914 |
stewteral |
Dec 30 2010, 11:28 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Fuel Injections Parts from ’73 1.7L :
Thermotime Switch, temp sensor controlling cold-start valve, 1.7-2.0,1970-76, (No longer Avail): $10 FI Trigger points: Bosch =311905301, Used, but perfect condition, (AutoAtlanta= $202.13): $25 Cold-start injector, VW =022 906 171 A, Bosch =0 280 170 018, (No Longer Avail.) $25 Aux air valve, VW =022 906 045, Bosch=0 280 140 007, 1.7 – 2.0, ’70-’76, (No Longer Avail.) $25 3-port fuel pump, VW = 311 906 091, 1.7 – 2.0, ’70-’76, (No Longer Avail.) tested: Works well. $55 Fuel pressure regulator, VW =311133 030, Bosch= 0 280 160 001, 1.7 – 2.0, ’70-’76, (No Longer Avail. )$10 Throttle body, VW =022 133 067, from ’73 1.7L $25 throttle position switch, VW =022 906 111 B, Bosch =0 280 120 021, 1.7L, ’72-’73, (No Longer Avail.) $25 injectors, VW =022 906 031 A or 311 133 261 A, Bosch =0 280 150 009, 1.7L, ’70-’76 $10 ea. ECU, VW =022 906 021 EU, Bosch =0 280 000 037, 1.7L =’72&’73, 2.0 =’73, idle mixture adj. knob $50 harness: complete for 1.7L, still flexible, outer insulation not broken $15 Terry stewteral@verizon.net |
kkid |
Dec 31 2010, 12:09 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Hey Terry,
I will take the Aux Air Valve. Will PM you. Thanks, kkid |
Markl |
Dec 31 2010, 02:54 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
Hi Terry, I'll take the thermotime switch and the cold start injector, sending PM
SchantzMD |
Dec 31 2010, 03:16 PM
Newbie Group: Members Posts: 33 Joined: 15-June 06 From: Riverside ca Member No.: 6,233 |
Hi Terry.
Interested in the 1.7L FI harness, do you have a cost shipped to 92509? |
kkid |
Jan 5 2011, 09:08 PM
I got the AAR today and it works fine. (IMG:style_emoticons/default/cheer.gif)
Thanks! Thus free bump (IMG:style_emoticons/default/smile.gif) |
detoxcowboy |
Jan 6 2011, 08:23 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
(IMG:style_emoticons/default/icon_bump.gif) for the excellent description and prices! some things sre not nla but still sweet prices..
usros |
Jan 7 2011, 05:25 PM
Newbie Group: Members Posts: 11 Joined: 29-August 04 From: Malvern, Oh Member No.: 2,647 Region Association: None |
Hi Terry,
I'll take the trigger points and harness. Where do I send the funds? Thom |
Rod |
Jan 11 2011, 04:28 PM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Send the trigger points and a set of injectors to the UK??
Lo-Fi Version | Time is now: 22nd June 2024 - 08:16 PM |
