> 914-6 oil tank question - too many orifices?
moparrob
post Feb 16 2011, 09:30 PM
For the longest time I was having difficulty trying to picture where the oil lines go to and from on a 914-6 conversion - but I think I have most of the issues figured out.
A lot of the problem has to do with the tank I bought. It has 'extra' holes and fittings that most other tanks I have seen did not have.
Here is a pic:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1297913412.1.jpg)
I finally figured out that fitting 'C' is the AN -12 return line which is usually a hard pipe from the engine which attaches to a flex line to this port.
Similarly, I figured that fitting 'D' is the supply line that goes to the oil cooler, which in my case is AN -16 on both ends.
The confusion arises out of fittings 'A' and 'B'. Most tanks I see do not have these fittings. Also, my car was only pre-drilled (by the PO) for fittings C,D, the filler, the vent and the filter only. I don't have extra holes for these fittings.
So, do I need these fittings A and B? What do they do?
If I don't need them, how do I get rid of them? Do I have to braze the holes shut? Or is it easier to just drill the two requisite holes in the engine compartment and use plugs on those fittings?
Last question, does anyone know the size and thread of those fittings?
Thanks in advance for your help.
Rob
Replies(1 - 19)
SLITS
post Feb 16 2011, 09:35 PM
"This Utah shit is HARSH!"
I can't remember if those are for an automatic transmission (some tanks had extra fittings) or some type of PO installed item.
Based on the "B" position, that would be supply and the "A" the return.
You only need "C" & "D"
Anyway, the experts will chime in in a moment.
Oh, I would say 3/8" pipe fittings.
post Feb 16 2011, 10:01 PM
914-6 GT in waiting
A lot more fittings than my OEM tank. I know there was a different version for the Sportomatic but I've never seen one in person. Maybe look at PET?
sixerdon
post Feb 16 2011, 10:13 PM
That is a sporto tank. Back in the 70's, I bought one to replace a leaking one in my /6 at the time. Stock tanks were already hard to find, but sporto's were available. What I did is take a copper penny (1981 or earlier) and brazed it over the openings. Never had a problem with leaks for the remaining time that I owned it.
Don
Cap'n Krusty
post Feb 16 2011, 10:28 PM
Cap'n Krusty
I can pretty much guarantee they're not 3/8ths pipe. Might want to check in the metric section of any good hardware supplier ........................
The Cap'n
moparrob
post Feb 16 2011, 10:30 PM
I wonder if they are pipe thread (taper) so that I could use a plug? Otherwise, if it is a straight thread I guess it would seal on the top surface with an aluminum washer?
Or perhaps I could unscrew those fittings and find threaded caps?
Eric_Shea
post Feb 17 2011, 10:34 AM
PMB Performance
Sporto. I'd take it down, have it properly welded, re-copper plated and re-painted.
post Feb 17 2011, 11:43 AM
Resident German
QUOTE(sixerdon @ Feb 16 2011, 08:13 PM) *
scotty b
post Feb 17 2011, 11:45 AM
rust free you say ?
MMMmmmmm AAHHHHhhhhhhhhhhh toasty radiant heat (IMG:style_emoticons/default/rolleyes.gif)
Cap'n Krusty
post Feb 17 2011, 12:19 PM
Cap'n Krusty
QUOTE(moparrob @ Feb 16 2011, 08:30 PM) *
I repeat. They're metric fittings, NOT pipe thread. Just get a couple of plugs, a couple of copper gaskets, and be done with it.
The Cap'n
laflaur
post Feb 17 2011, 12:46 PM
Hey are those pipe thread fittings?
moparrob
post Feb 17 2011, 02:18 PM
(IMG:style_emoticons/default/stirthepot.gif)
Cap'n, I was trying to avoid cutting two additional holes for those fittings to stick out of, but your advice is well taken. That may be the easier course of action.
Now if I could only figure out where the heck to layout the holes before I start drilling ... (IMG:style_emoticons/default/confused24.gif)
post Feb 17 2011, 03:02 PM
Resident German
QUOTE(moparrob @ Feb 17 2011, 12:18 PM) *
I would think that a stock 914-6 sport-o-matic oil tank would be worth more to the right buyer than a standard tank ...
Why not sell it and buy a correct one and pocket some money in the process??? (IMG:style_emoticons/default/confused24.gif)
They made only what, 25 914-6 sportos? (IMG:style_emoticons/default/idea.gif)
jeff
post Feb 17 2011, 04:13 PM
http://www.pegasusautoracing.com/productde....asp?RecID=4060 Maybe?
moparrob
post Feb 17 2011, 05:06 PM
QUOTE(SirAndy @ Feb 17 2011, 01:02 PM) *
Hmmm, not a bad idea.
Think I'll give it a try....
moparrob
post Feb 17 2011, 05:08 PM
QUOTE(jeff @ Feb 17 2011, 02:13 PM) *
Except those are tapered threads and per prior posting the threads are not tapered...
SLITS
post Feb 17 2011, 06:28 PM
You can make a cardboard template and register off the other holes to know where to drill if it comes to that.
Eric_Shea
post Feb 17 2011, 06:42 PM
PMB Performance
This is painful to watch... (IMG:style_emoticons/default/sad.gif)
SLITS
post Feb 17 2011, 06:50 PM
QUOTE(Eric_Shea @ Feb 17 2011, 04:42 PM) *
Close your eyes and the pain will go away! (IMG:style_emoticons/default/slap.gif)
hwgunner
post Feb 17 2011, 08:29 PM
914 Parts @ Discount Prices 800.321.5432
QUOTE(SLITS @ Feb 17 2011, 04:50 PM) *
Well said! (IMG:style_emoticons/default/sheeplove.gif)
- Lo-Fi Version Time is now: 5th February 2025 - 12:57 PM
