Flapping headlight |
matteyp |
Feb 17 2011, 10:55 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
Hey guys, just wondering if anyone had a problem with there headlights flapping up and down without stopping. For some reason I cant figure out why my passenger headlight motor constantly runs up and down when I turn on my lights. I checked the ground and sanded it it real well and that doesn't seem
To be the problem. Could my motor be bad? Any suggestions would be great. Thanks Matt |
TROJANMAN |
Feb 17 2011, 10:59 PM
Looks nice in pictures......... Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
replace the relay
DanT |
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
check your little round headlight relay. It is under the plastic cover to the rear and under the motor...they get corroded or go bad and cause the headlight motors to cycle. (IMG:style_emoticons/default/biggrin.gif)
clean all the terminals. try switching it with the passenger side and see what happens. |
matteyp |
Feb 18 2011, 12:33 AM
Hey thanks for the suggestions. I totally should have thought of that. Prolly somethin simple. Would this cause the headlights to not come on? Neither one of them will turn on. Thanks.
mrdkrantz |
Feb 18 2011, 07:41 AM
Newbie Group: Members Posts: 35 Joined: 28-December 10 From: Eastern Shore MD Member No.: 12,532 Region Association: North East States |
If I remember correctly the headlights not turning on is a relay on top of the fusebox. Mine went bad a couple of years ago. They would pop up and would go down but would not light.
I replaced the relay on top of the fusebox and bam... like new The motors and lights turning on is two different relays |
matteyp |
Feb 18 2011, 02:33 PM
Wow ok, will check that out. Checked motor relay both are fine. Guess I will keep messin with it till I figure it out. Kinda funny these cars are like puzzles. Soon I will have all the peices!
Lo-Fi Version | Time is now: 26th December 2024 - 07:24 PM |
