starter motor wiring, help please |
rwilner |
Feb 20 2011, 09:44 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
During my enthusiasm for my transmission drop, I neglected to properly document how the starter motor is wired.
Of course, some wires are cut or missing which makes this a bit more challenging than it might otherwise be (car did start and run prior to the drop) -- check out pics for 2 wires cut back in the small-gauge harness. Can someone take a look at the pics below and let me know if I've got it right? (The pics are rotated 90 degrees ccw for some reason.) Thanks TERMINALS SIDE VIEW |
Tom |
Feb 20 2011, 11:17 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Rich,
Yep, looks like you got it right! Tom |
IronHillRestorations |
Feb 20 2011, 11:30 AM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yea, that looks right to me. Get a new boot for the wires though, they aren't too expensive and will help keep the road grime off.
rwilner |
Feb 20 2011, 02:49 PM
Thanks guys. Are the wires hat are cut off for the reverse switch?
Tom |
Feb 20 2011, 06:17 PM
I think so. Mine has an additional two wires that do go to the reverse switch. I always play it safe when I've done things like this and leave the negative battery terminal untightened - just pushed on snug, just in case. After testing, then tighten it up.
Tom |
underthetire |
Feb 20 2011, 06:55 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
The smaller of the two battery leads looks bent over kinda close to the solenoid mounting screw. Might wanna double check it. If it touches, you will have a Chinese new year party going on.
Lo-Fi Version | Time is now: 27th September 2024 - 12:42 PM |
