dumb D-Jet question, is there a specific way connectors have to go in? |
DrifterJay |
Feb 23 2011, 04:05 AM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
Okay, after dealing with my whole car not shutting off issues, I started to do some harness overhaul. This involved the removal of my ignition harness and injection harness. I ended up replacing about 10 feet of crappy wiring (repaired right with solder and shrinkwrap..) in my ignition harness and the repair of a handful of cracked wires on my injection harness. Put it all back together... now she won't start. Fanfuckingtastic. One thing I noticed on the d-jet harness is that on most of the plugs, they can go into the female receptacle either way. Does it matter which way they go in? Especially on the distributor, tps and mps? They slide in relatively easily both ways... (IMG:style_emoticons/default/dry.gif)
larss |
Feb 23 2011, 05:45 AM
Member Group: Members Posts: 431 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
It does not matter which way the injector plugs goes in but I thougt, without having the possibility to try my own plugs right now, that TPS and MPS were only possible to fit one way since it should matter if they were fitted the wrong way.
/Lars S |
76-914 |
Feb 23 2011, 08:52 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,663 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) if it matters then the plug will only fit one way. If it doesn't then it doesn't matter. See Jeff Bowsley's link. http://bowlsby.net/914/Classic/TechNotebook.htm
JeffBowlsby |
Feb 23 2011, 09:34 AM
914 Wiring Harnesses Group: Members Posts: 8,819 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Most of the D-Jet connectors are symmetrically wired or non-sexed...it does not matter which way they are installed.
The TPS however can only be stalled correctly one way, and the wires have to be in their correct cavities. Same for the connections at the ECU and relay board. Be sure your circuitry is correct and that the correct wires are in their correct cavities. Easy to do a continuity test to verify. FI grounds hooked up correctly? |
TheCabinetmaker |
Feb 23 2011, 10:00 AM
I drive my car everyday Group: Members Posts: 8,326 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Make sure the 16 pin connector on the relay board is not pluged in one pin off.
Lo-Fi Version | Time is now: 5th February 2025 - 01:38 AM |
