> 1.8 case dimentions
tracer
post Feb 23 2011, 09:23 AM
Hi Everyone, Does anyone know what the hole opening size is for the cylinders to fit into the case. I measure 100mm which I believe is the stock size. Reason I am asking is the previous owner of this engine installed oversizes piston/cylinders which bumped the 1.8 up to 1.9 I believe. I see some milling is present on the heads but that is all I can see so far.
Replies(1 - 2)
Cap'n Krusty
post Feb 23 2011, 09:36 AM
Cap'n Krusty
Most likely he used the readily available aftermarket cylinders which require no case machining. In fact, most kits don't require the heads to be opened up, either.
The Cap'n
tracer
post Feb 23 2011, 10:25 AM
Great, That's what I thought. Thanks
- Lo-Fi Version Time is now: 27th December 2024 - 02:28 AM
