Removing Rear View Mirror, Adhesive is strong |
turnaround89 |
Feb 23 2011, 09:36 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
So i accidentally hit my rear view mirror while working in my car and it snapped off, the screw sheared and just the little block is attached to the windshield. I would like to replace the mirror, but can't with the black block in the way. Any tips on how to remove that, the adhesive is wicked strong?
Thanks everybody |
ConeDodger |
Feb 23 2011, 09:42 PM
Apex killer! Group: Members Posts: 23,852 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Heat activates most adhesives... I am not suggesting though that you heat up just that spot of the windshield. Hot day, sharp - sharp blade.
turnaround89 |
Feb 23 2011, 09:43 PM
little cold here is rockford to try that, but when it warms up, i will definitely give that a shot...Thanks
ConeDodger |
Feb 23 2011, 09:51 PM
little cold here is rockford to try that, but when it warms up, i will definitely give that a shot...Thanks I'm from the Midwest Andrew. I hear that! I said that to make sure that you don't use a heat gun or hair dryer to spot heat the outside of the window at that spot. I suspect you could cause a crack. |
Lo-Fi Version | Time is now: 26th December 2024 - 07:46 PM |
