> Dumb *** question, Wireing that goes through shifter tunnel
ventedrib
post Feb 25 2011, 03:06 PM
The wireing that goes through the shifter tunnel comes out the fire wall in to the engine compartment splits it has a big end that goes to the relay board and it has a small end that contains 3or4 I can't remember now red wires where do those go.I can't remember if they went to the starter or the alt. or does it matter they just power up the accessories correct.
Replies(1 - 4)
Mike Bellis
post Feb 25 2011, 03:21 PM
Resident Electrician
Battery
Spoke
post Feb 25 2011, 03:22 PM
Jerry
The wires going toward the battery are the main feed for the entire electrical system and for the fuel pump if still in the original location under the battery area.
The alternator and starter wires stay in the rear of the car. The only wire going from front to rear is for the starter wire from the ignition key switch.
Eric_Shea
post Feb 25 2011, 04:12 PM
PMB Performance
(IMG:style_emoticons/default/agree.gif) battery and fuel pump.
ventedrib
post Feb 26 2011, 03:51 PM
QUOTE(Eric_Shea @ Feb 25 2011, 04:12 PM) *
Thanks guys thats what I needed issue solved.
- Lo-Fi Version Time is now: 27th December 2024 - 02:48 AM
