Tire shortage???, trying to find Falken Azenis-205/50/15's |
Mueller |
May 11 2004, 03:57 PM
Everyone seems to be back ordered on these tires in this size.
I'm going to need new shoes for my 914 (IMG:style_emoticons/default/MDB2.gif) Best prices seem to be here (62 ea): Vulcan Tire Wheel Works wants 120 ea, but when i mentioned the internet, they say the closest they can come to that price is " price+$20 per tire" What is my next best bet tire wise in this price/preformance range?? |
seanery |
May 11 2004, 04:00 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
you looking for a harder DOT-R tire?
the a032 is harder but more like $150. The soft stuff won't stand up to any street use. |
MJHanna |
May 11 2004, 04:35 PM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
Yokos
AVS ES100 Ultra-high value and performance. V-speed rated. 205/50R-15 86V BSW Reading the Tire Size $80.00 ea. discount direct |
Part Pricer |
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Dave_Darling |
May 11 2004, 05:40 PM
914 Idiot Group: Members Posts: 14,996 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I'm told that the local Sears can get the Azenis... Might be worth a look.
Kumho 712s are supposed to also be good hard-compound tires. Bridgestone S-02s and S-03s, but I don't know if they come in 15" sizes. BFG Comp TA-KD tires are also supposed to be good. Generally, the Azenis are the cheapest of the lot. I've run some of the Sumitomo tires (also quite cheap) on my yellow car, and wasn't all that impressed. They were OK, but only OK. --DD |
Mueller |
May 11 2004, 06:53 PM
I've got the Kuhmo 712s on my 911, not too bad, the Falkens supposed to be a little softer and I figured these are a good choice to go with until I get some more auto-x time in my 914 before I step up to more dedicated and serious tires.
According the thier website, Discount Tire has them in stock as well, cheaper grand total since shipping is free. |
GaroldShaffer |
May 11 2004, 09:22 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
QUOTE I'm told that the local Sears can get the Azenis... Might be worth a look. I was told the same but when I called the Local Sears I was told they don't have them in stock in that size. They can order them...yada yada yada... -Garold PS order mine from Vulcan Tire a few months ago. Got here in 4 days. |
DNHunt |
May 12 2004, 08:32 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I was told the Falkens are on national backorder and the company should do another run soon. I decided to go with Yoko AVS ES100 205 55 15's. Close to the right diameter. Like them pretty well so far. Nice on the highway. Pushed in tight corners at AX but that's probably the rest of the setup and I might get that better.
Dave |
maf914 |
May 12 2004, 08:45 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Dave,
How is the tire noise with the ES-100 tires. I'm considering the Yoko AVS ES-100 and the AVS dB-S2. Now, don't laugh when I ask about the tire noise. I figure i've got enough noise, or should I just say sound, with the Weber carbs growling away behind me. (IMG:style_emoticons/default/laugh.gif) I'll go with 205/60's as I currently have. |
DNHunt |
May 12 2004, 08:49 AM
Mike
I cant tell. I don't here anything over the other noises. Dave |
Mueller |
May 12 2004, 09:18 AM
Hey Dave,
Are you rims the stock width or did you have them widened up a tad? |
DNHunt |
May 12 2004, 09:24 AM
I got them on 6" wide Empi (I know:barf:) rims. The guys mounting them had a hell of a time getting them to seal. Been just fine though.
Dave |
Mueller |
May 12 2004, 09:34 AM
Empi's??
So you have two sets of rims/tires or you are no longer running the steel rims? I'm just going to bite the bullet and get Kuhmos 712's (205/55/15) mounted on my 15x5.5 Enkies (current tires are old Pirelli P 4000 sized 205/60/15) to use as street tires. I have one perfect Fuch, so now I just need to find 3 more at a reasonable price or find something else...I really want Panasports, but they are hard to get right now, besides the price is very steep at about $230 or more per wheel...ouch !!!! I'd be happy with another set of Enkies if anyone has a set (IMG:style_emoticons/default/smile.gif) |
DNHunt |
May 12 2004, 09:38 AM
seanery |
May 12 2004, 11:00 AM
Dave, dontcha have some clients who may need an extra root canal, filling, etc... ? (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 23rd June 2024 - 01:36 PM |
