rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
I have a 1978 3.0 with Weber carbs installed in my 75 GT clone. She runs good but is cold blooded but good throttle response. Engine is stock internally. I just picked up a 3.2 intake setup complete with manifolds,throttle body,fuel rails,injectors and injector harness. So to complete the package I could go after OEM ECU but then I would have to mount the sensors on the transmission. Or I could go aftermarket ECU and just use TPS/MAP. I'm in no rush as this will probably be next winters project. So what aftermarket ECU's do you guys recommend ? I do not want Megasquirt I had a bad experience with that and never again. Also not sure if I want fuel injection only or injection/ignition. I do have a complete EDIS from years ago that could be used. And finally anyone in the Atlanta area that can install/fine tune ? I can install everything but would need help fine tuning. So what suggestions do you have ?
Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I have a 1978 3.0 with Weber carbs installed in my 75 GT clone. She runs good but is cold blooded but good throttle response. Engine is stock internally. I just picked up a 3.2 intake setup complete with manifolds,throttle body,fuel rails,injectors and injector harness. So to complete the package I could go after OEM ECU but then I would have to mount the sensors on the transmission. Or I could go aftermarket ECU and just use TPS/MAP. I'm in no rush as this will probably be next winters project. So what aftermarket ECU's do you guys recommend ? I do not want Megasquirt I had a bad experience with that and never again. Also not sure if I want fuel injection only or injection/ignition. I do have a complete EDIS from years ago that could be used. And finally anyone in the Atlanta area that can install/fine tune ? I can install everything but would need help fine tuning. So what suggestions do you have ? I'm sort of working on the same idea for my 911 using PMO itb's. I'm looking at using the Holley HP EFI ecu. I have a Holley HP on my 914 3.8V6 using a 4bbl tb. The system works very good and once a base map is setup it will self tune from there. Paul |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Many guys run Megasquirt. If you fab the TPS, Air Temp sensor and Engine temp sensor you can use factory FI runners, plenum and injectors. You could fad a complete system if you wanted. On my conversion project, I'm using a Haltech ECU. The engine is EFI ready so it's a little easier but still work. If you want to play, I have an extra Megasquirt ECU built and ready to deploy. I'll let it go cheap. Any ECU will work. Some work better than others. If you want top of the line EFI expect to spend $2k on an ECU and another $3k on fabrication and electronics. My Haltech is a mid line unit cost $1k for the ECU. You can buy a new Megasquirt ECU online for $300.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Do you already have a MSD?
http://www.sdsefi.com SDS crankfire using MSD (crane,etc) $1283 MAP $70 temp sender $21 Pump relay $30 And you'll need a O2 meter for any system that you choose. Fine tune it yourself. |
rfuerst911sc |
Do you already have a MSD? http://www.sdsefi.com SDS crankfire using MSD (crane,etc) $1283 MAP $70 temp sender $21 Pump relay $30 And you'll need a O2 meter for any system that you choose. Fine tune it yourself. Yes I'm currently running the factory ignition distributor that has been recurved for carb's with a Mallory multi-spark CDI. And I will use a wideband O2. I do like the simplicity of the SDS setup. |
Mark Henry |
Do you already have a MSD? http://www.sdsefi.com SDS crankfire using MSD (crane,etc) $1283 MAP $70 temp sender $21 Pump relay $30 And you'll need a O2 meter for any system that you choose. Fine tune it yourself. Yes I'm currently running the factory ignition distributor that has been recurved for carb's with a Mallory multi-spark CDI. And I will use a wideband O2. I do like the simplicity of the SDS setup. I forgot the TPS you'll may need that as well. |
rfuerst911sc |
Do you already have a MSD? http://www.sdsefi.com SDS crankfire using MSD (crane,etc) $1283 MAP $70 temp sender $21 Pump relay $30 And you'll need a O2 meter for any system that you choose. Fine tune it yourself. Yes I'm currently running the factory ignition distributor that has been recurved for carb's with a Mallory multi-spark CDI. And I will use a wideband O2. I do like the simplicity of the SDS setup. I forgot the TPS you'll may need that as well. I thought the factory throttle body has a TPS ? |
Mike Bellis |
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
If you want a simple system, then the SDS is the best, per Mark's comments. Hardest part of the install is mounting the control unit. I have a link in my signature giving details of my installation. Tuning was relatively easy. I also think that Jake sells complete systems. JoeO
Lo-Fi Version | Time is now: 26th June 2024 - 06:31 AM |
