The usual problems |
dbelleperc |
Apr 15 2003, 02:12 AM
DoN't MaKe FuN oF mE i Am SlOw Group: Members Posts: 61 Joined: 12-March 03 From: San Diego, CA Member No.: 418 |
When I am driving my 914 1.7 around a right hand corner the car looses power and jerks and jerks until I get it straighten out and the power will come back to normal. The same thing happends when I make a left hand turn but not as often and it also happens when I pull away from a light but it also doesn't happen all the time. Is this a "CHECK YOUR GROUNDS" situation or is there another problem with my car. Thanks in advanced.
sechszylinder |
Apr 15 2003, 02:31 AM
Member Group: Members Posts: 256 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None |
i guess thats an electrical problem. check not only your grounds but also all other connections. have a look at your fuel pump ...
benno |
Brad Roberts |
Apr 15 2003, 11:34 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Hi David,
welcome to "this" board. Check and see if your coil is tight. The Bosch Blue coil that everybody likes to run doesnt fit the stock coil clamp correctly and can rotate against the engine tin and arc out on corners. Then get back to us. I dont think this is a ground problem like we normally see. B |
need4speed |
Apr 15 2003, 12:48 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
Does oil slosh around in the T4 engine pan on turns like it does with the T1 (VW Beetle) engine?
JWest |
Apr 15 2003, 01:43 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Yes, it has similar oiling issues. The "tuna can" is a popular solution.
dbelleperc |
Apr 15 2003, 07:38 PM
I checked the coil and it is in there tight. How would I check the fuel pump? And "Forgive me Father I have sined" [not religious just saying it] I have been hanging around Pelican and Rennlist to much and not been able to help out you guys and girls [If there is any here] but Pelican and Rennlist have seemed to be getting really slow so I think I will be hanging around here more often.
seanery |
Apr 15 2003, 08:38 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
The atmosphere here is great!
No tudes and lots of good stuff. |
Bleyseng |
Apr 15 2003, 09:58 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
For the fuel pump, just carefully pull the leads off and clean them. Check and clean all your grounds, that corrode and cause problems
Geoff |
Lo-Fi Version | Time is now: 21st December 2024 - 07:07 PM |
