joea9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None ![]() |
Back a while ago some guy was putting a kit together to stiffen the inner Longntudes (sp) .
Did the kit ever happen ? Looked like he was close to being done ? If it did happen has anyone used one ? I cant find the original thread. Thanks |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
I have them. They rock. He posted them in the vendors area. If I had easy access to a camera I'd shoot pics for you.
B |
STL914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest ![]() |
Here's a link:
http://www.914world.com/bbs2/index.php?act...=ST&f=4&t=12376 His name is Mark Bland, or ENGMAN. Set of 3 pieces go for $259 plus shipping. Happened to see a set at the Funfest last Saturday. His parts look very good, top quality. |
joea9146 |
Thanks for the link.... Whats going on Here ? Is that just bent up and welded against the Firewall ?
Attached image(s) ![]() |
Engman |
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 ![]() ![]() |
Ummmmm.... That is a hole at the back of my firewall that I have to weld in a cover plate. I cut out the rust in the hell hole and I mean I cut out alll the bad. Wanted good metal to weld to. Fixed the hell hole except for this and a minor bit of the engine shelf left to weld up.
Hope this helps to explain the circled area. M |
eresener |
Dr. Sawsall ![]() ![]() Group: Members Posts: 218 Joined: 17-October 03 From: Missouri Member No.: 1,252 ![]() |
I picked up a kit at the Funfest.... for my son's project car....and it slipped right in with NO PROBLEMS...very nice...buy it.... it is well worth the $$... plus easy to install....our next step is to install the floor pans...ours were totally trashed...when we get it all together I'll post a shot or two and give Mark more glowing testimonials.... (IMG:style_emoticons/default/wink.gif)
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Are there any pic's showing the hand brake area and how it is dealt with?
Thanks, Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 09:21 AM |
