sawtooth |
Member ![]() ![]() Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region ![]() |
After getting the entire wiring harness back in my car, and putting in my new engman fuse panel, somehow I managed to add a feature where the ignition coil wire loses power when the starter is cranking. As soon as I let up on the starter the ignition coil wire gets 12v again. I used this wire to power my subaru ecu before, but this new behavior doesn't work so well for starting. What could I have done wrong to cause this? Possibly hooked something up backwards on the fuse panel?
The wire is the T8 black wire on the 914 relay board pinout. ![]() |
sawtooth |
Found the wiring diagram I was looking for. It looks like T8 goes to fuse panel #9. I must have hooked that up wrong on the fuse panel. I'll have to check that tonight. |
sawtooth |
Found the problem. The new ignition switch I put in last year is bad already. When cranking starter you have to hold the key just right to get it to make contact on #15 which leads to #9 fuse which leads to ignition coil. Time for another new switch.
Lo-Fi Version | Time is now: 29th June 2024 - 10:12 AM |
