Clutch, Flywheel, etc, While the engines out |
newdeal2 |
Jun 23 2004, 09:38 PM
Unregistered |
My clutch was replaced about 2 years ago by the PO and looks OK but since the engine is out should I spend the $ and put in a new 3 piece? The flywheel looks a bit worn so I'm thinking a NEW one as opposed to a re surface? Is it nessesary to replace the flywheel bolts [they had no washers...hmmm]?
My budget is getting thin real fast so any advice is welcome. |
Brad Roberts |
Jun 23 2004, 09:46 PM
Hey Peter,
Unless your flywheel bolts are beat up... no need to replace them. I personally would buy a new lightened flywheel and switch the car over to a 911 6 spring disc and a stock pressure plate. Dont forget: felt washer locking plate pilot bearing clutch fork pivot bushing throw-out bearing B |
Bruce Allert |
Jun 23 2004, 11:05 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
QUOTE(Brad Roberts @ Jun 23 2004, 08:46 PM) Dont forget: felt washer B (IMG:style_emoticons/default/ohmy.gif) I don't remember a felt washer (IMG:style_emoticons/default/unsure.gif) where'zat go (IMG:style_emoticons/default/confused24.gif) and what happens it it ain't in thar? Oh! I din't do new I did used... did it come away with one of the parts??? (IMG:style_emoticons/default/cool.gif) .......b |
Dave_Darling |
Jun 24 2004, 10:24 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I believe it goes into the flywheel with the pilot bearing. You put oil on it and it helps keep the pilot bearing lubed. A used flywheel may very well still have it in there.
--DD |
Lo-Fi Version | Time is now: 20th October 2024 - 02:49 AM |
