Dash Lights, Not working anymore any ideas why? |
Ian Stott |
Jul 17 2011, 12:03 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Dash lights just stopped working, advice was the switch, just play with it; that didn't work so I changed the switch with one from a 74 (my 914 is a 73) still no dash lights so put switch back in from the 73 still no lights. Any ideas why??
Ian Stott Moncton Canada |
detoxcowboy |
Jul 17 2011, 12:30 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Sounds stupid the know is a rheostat and you have to trun it all the way to the right for dash light brightness and on / off if you have led then there is no dimmer actuation just on or off.
Also check first power/ground at the switch and then behind the gauges. |
76-914 |
Jul 17 2011, 03:04 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Also, be sure that the rheostat winding is intack (looks like a spring wrapped around the end of the shaft).
Dave_Darling |
Jul 17 2011, 06:50 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
How about the fuses?
You can bypass the switch to test it, as well. --DD |
Drums66 |
Jul 18 2011, 11:27 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
How about the fuses? You can bypass the switch to test it, as well. --DD I'm with ya(my thoughts) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif)(also light sockets) |
Lo-Fi Version | Time is now: 26th June 2024 - 04:18 AM |
