andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Painted the car finally - I took two days to do the sealer, base, and clear (It took me nearly 5 hours just to mask and skirt, as I put the car on jack stands). Color is GT Silber. Used (very) $$$ PPG.
Scottyb, you were right about the amount of base. I used just under than 2 quarts for three coats (the cabin, engine bay, and inside both trunks were already done). PPG does not recommend reducing the clear, but every painter I talked to said to reduce it. Guy that owned the booth said to reduce the hell out of it, and as it turns out, that worked out really well. I started the initial color sanding with 1000 grit to knock it down before the clear got too hard. Managed to get about 3 1/2 corners of the car complete; then on to the doors, trunks, lid, and targa. I'll do final sanding and buffing after assembly (cause you never know what oops might happen!). Andys Attached image(s) ![]() |
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
NICE!!!
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Painted the car finally - I took two days to do the sealer, base, and clear (It took me nearly 5 hours just to mask and skirt, as I put the car on jack stands). Color is GT Silber. Used (very) $$$ PPG. Scottyb, you were right about the amount of base. I used just under than 2 quarts for three coats (the cabin, engine bay, and inside both trunks were already done). PPG does not recommend reducing the clear, but every painter I talked to said to reduce it. Guy that owned the booth said to reduce the hell out of it, and as it turns out, that worked out really well. I started the initial color sanding with 1000 grit to knock it down before the clear got too hard. Managed to get about 3 1/2 corners of the car complete; then on to the doors, trunks, lid, and targa. I'll do final sanding and buffing after assembly (cause you never know what oops might happen!). Andys That is pretty! |
TurboWalt |
Member ![]() ![]() Group: Members Posts: 157 Joined: 14-March 10 From: Chattanooga, TN Member No.: 11,463 Region Association: Northern California ![]() |
Looking good!
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
I am so looking forward to some year being able to post a picture of my chassis all nice and painted. Your car looks terrific; excellent color.
914Mels |
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California ![]() |
Painted the car finally - I took two days to do the sealer, base, and clear (It took me nearly 5 hours just to mask and skirt, as I put the car on jack stands). Color is GT Silber. Used (very) $$$ PPG. Scottyb, you were right about the amount of base. I used just under than 2 quarts for three coats (the cabin, engine bay, and inside both trunks were already done). PPG does not recommend reducing the clear, but every painter I talked to said to reduce it. Guy that owned the booth said to reduce the hell out of it, and as it turns out, that worked out really well. I started the initial color sanding with 1000 grit to knock it down before the clear got too hard. Managed to get about 3 1/2 corners of the car complete; then on to the doors, trunks, lid, and targa. I'll do final sanding and buffing after assembly (cause you never know what oops might happen!). Andys Very clean looking. Is that a radiator up front or do you just have a really big A/C condenser? |
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Great looking paint job!
How much did it cost to rent the paint booth? |
jim dorociak |
Member ![]() ![]() Group: Members Posts: 95 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California ![]() ![]() |
so what are your plans for tires and wheels? Are those on the car just rollers? 17"? I could build you a set of 18" wheels with the correct offsets. jdorociak@gmail.com
Jim |
andys |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Looks great! Thats a hard color to get right!
andys |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Very nice !!
BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
Looks great !
Can't wait to see it all back together. Bob |
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
Nice wheel combo. What size spacers are you running?
Matt |
andys |
Nice wheel combo. What size spacers are you running? Matt I have custom trailing arms in the rear, so my off set is different than if they were stock. On the front, I have 2" spacers. Though the wheels fit the flare nicely, there are two problems. First, the tire (205-17) rubs the wheel well at full lock. I originally calculated the spacer should be 1 5/8". Since only 1 1/2" and 2" were available, I went with 2" (I didn't think it would rub, but I was wrong). The second problem I anticipate will be higher steering effort and kick-back due to the increased scrub radius.....Won't know for sure until I get it on the street or track. Andys |
jim dorociak |
Andys - are not the guys running 7 x 16" fuchs still using a spacer to fill the wheel well? So the width is really not the issue as much as the offset of the wheel - this is a statement and a question. When I build for widebody 911 cars - turbo cars have built in spacer into the front hub that moves the wheel out approx 21mm. I build 8.5" front wheels using 6.5 inner and 1.75" outer. I could build with a 2.25 and a 5.5 and make an 8" but everyone seems to want the largest wheel front and rear they can get. I have a front wheel here that is 5.5 inner rim and 2.75" outer rim making a 8.5" wheel this offset if very close to the 4 7/8 of a fuchs wheel. I have been saving parts for a set of wheels for my not yet started 914 project car. Jim jdorociak@gmail.com
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,344 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Andys, that looks very nice.
My flared roller is going into the booth in a few weeks and it will be getting a Colour Change to Silber T.C. the Before ![]() My Goal ( a previous -6 I had) I will be going with Rota-Fox 17"s Powder Coated Diamond Blue ![]() |
914.SBC |
Member ![]() ![]() Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None ![]() |
Wow, I really like the color and the rims...Nice Job@@@
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Nice job. (IMG:style_emoticons/default/first.gif) FWIW I reduce the hell out of PPG too. Usually 15-20 percent, but then again I even reduce thin ass Nason too (IMG:style_emoticons/default/unsure.gif) Might want to consider wet sanding and buffing the removable panels and body edges before assembly, It will make for a better job, Tape off all the edges when assembling to prevent the " oopses "
andys |
Andys - are not the guys running 7 x 16" fuchs still using a spacer to fill the wheel well? So the width is really not the issue as much as the offset of the wheel - this is a statement and a question. When I build for widebody 911 cars - turbo cars have built in spacer into the front hub that moves the wheel out approx 21mm. I build 8.5" front wheels using 6.5 inner and 1.75" outer. I could build with a 2.25 and a 5.5 and make an 8" but everyone seems to want the largest wheel front and rear they can get. I have a front wheel here that is 5.5 inner rim and 2.75" outer rim making a 8.5" wheel this offset if very close to the 4 7/8 of a fuchs wheel. I have been saving parts for a set of wheels for my not yet started 914 project car. Jim jdorociak@gmail.com Jim, I'm having a little trouble following you're post. My wheels are stock 993; 7.5" front, and 9.5" rear (IIRC). I don't remember the offsets, but I calculated my spacer dimensions for the rear based on wheel well fit (since there's barely enough room for the 255-17"s). On the front, I needed 1 5/8" spacers to put the wheel in the correct place (scrub radius wise), but as I mentioned earlier, I went with 2". In an earlier post, I think you mentioned building a set of custom wheels. Though I intend on keeping what I have for now, what kind of custom wheels do you offer? I'm not a fan of large diameter wheels on a 914; 17" to me are already a bit large, and I don't personally like that Chip Foose wheel look on 70's vintage cars. 15" just look right to me (IMHO). Andys |
Lo-Fi Version | Time is now: 26th June 2024 - 05:57 AM |
