SuperPorsche914 Major Step Forward, Timing Done Yahooooo |
superporsche914 |
Jul 19 2011, 01:19 AM
Newbie Group: Members Posts: 16 Joined: 9-January 06 From: Milpitas, CA Member No.: 5,396 Region Association: Northern California |
Well it took awhile to get this accomplished. But with all the stuff under the hood and no way to get to the Balancer. I had to coem up with another way of timing this beast.
Her's what I did. Bought a tool for finding TDC. Put it cyl #5 Spend 1 hour back and forth getting it set. Then drilled a hole thru the bell housing ontop of the flywheel 1/8 bit marked the flywheel with pop through The engraved the hosing for 0 mark Then made a larger hole for viewing timing. Then engraved a line on the flywheel on marked spot. (1/8" bit mark) Then did some studing online about turbo timing. found out that I need to eliminate the vac advance. Done. Then started car timed in using cyl 5 then a freind total turbo master. and we reset timing by using the total at high rpm. Put the car back together and rove it. WOW it is awesome. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) I will be taking pics in the sun on tuesday and posting them I will be trying to make the meet in Sac on Sat. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:33 AM |
