Dave Avery |
Unregistered ![]() |
Hey guys
anyone have a set kicking around? Now that I need a set, they have become most scarce or most uber-priced. I sold a set for $600 a few years ago (not perfect of course) but now that I need them, they are through the roof (of course) Thanks! |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
there are different 8s. Which ones are you looking for?
Dave Avery |
Hi Seanary
Thanks for the reply. Looking for 911 rear 8's , not 951 8's (front of a 911). Thanks for pointing this out, probably save me some time (IMG:style_emoticons/default/smile.gif) -DMA |
jgiroux67 |
Guitar Shredder ![]() ![]() ![]() Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 ![]() |
QUOTE(Dave Avery @ Jun 28 2004, 10:05 AM) Looking for 911 rear 8's , not 951 8's (front of a 911). What is the difference and what is better to use on a flared 914? |
seanery |
depends where you want to use them. 951 8's are great on the front with 9s on the rear.
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
FWIW, I have a set of 7&9's that I use on my 914 (from a 930), and a set of 7&8's also, Im not sure where the 7&8's are from though.
Bigbohr |
Superlurker ![]() ![]() Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 ![]() |
QUOTE(jgiroux67 @ Jun 28 2004, 03:03 PM) QUOTE(Dave Avery @ Jun 28 2004, 10:05 AM) Looking for 911 rear 8's , not 951 8's (front of a 911). What is the difference and what is better to use on a flared 914? The part number of the 8" x 16" Fuchs wheels that came on a 944 started with 951. The part number of the 8" x 16" Fuchs wheels that came on a 911 started with 911 (duh!). The offset of the 951 and 911 8" rims is different. 951's have a 23.3mm offset and 911's a 10.6mm offset, i.e., the 911 wheel would stand further from the chassis. Personally I like more the look of the 911 wheel since the center sits deeper in the rim. For usage with flares I'd think a 911 wheel would be better since it would require less spacer in the front to fill out the flare. I have 7.5" x 17" rims with 23mm offset for the front and will need a substantial spacer. In the rear you probably don't need a spacer with 911 wheels if you put a 245 series tire on. Drawback is that 911 8" wheels are more expensive than 951's. |
Dave Avery |
Hi guys
Sorry not to get back... the email thingie didn't let me know anyone replied (IMG:style_emoticons/default/sad.gif) Anyhow, I found a set... a local guy had a set on ebay, and I convinced him to end the auction early if I pick them up, pay cash, etc. He agreed, and I got a SWWWWWEEEEET set of 16*7/*9 with one .5" blemish, newly mounted ZR tires, for $1300.00. I had another deal in the works for $2200.00. Not bad (IMG:style_emoticons/default/smile.gif) Thanks, DMA |
Lo-Fi Version | Time is now: 1st July 2024 - 10:27 AM |
