> Dam TACO plate :(
Kerrys914
post Jul 6 2004, 02:38 PM
Dear, the parts I just sold paid for that part ;)
Changed my oil this past weekend and fixed my non-working oil temp gauge (IMG:style_emoticons/default/smile.gif) The bad news is the dam taco plate is leaking oil now. Argggggggggggggggggggggggg (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
I had the engine sealed up nicely after the last oil change. The problem I made during the last oil change/sender install was I put sealant between the sender plate and the block. FYI the sender plate needs good contact with the block to work right (well at least mine does).
Now I need to drain the oil and fix the leak and refill with new oil. (IMG:style_emoticons/default/headbang.gif) .
Does anyone have a good solution for this nasty leak? I assume some good high temp sealant and a paper gasket is what is needed. FYI the leak is not coming form the bolts.
Oh yea, I picked up a sealed battery from SAMS (IMG:style_emoticons/default/smile.gif) So someting did go right this weekend. (IMG:style_emoticons/default/driving.gif)
Cheers
Kerry
Replies(1 - 3)
Andyrew
post Jul 6 2004, 03:03 PM
Spooling.... Please wait
Oh hey, almost the same problem as me.. but I had to drain the oil and put new oil in it three times...
Glad I used dino..
Sorry, no help on fixing the leak..
Andrew
Joe Bob
post Jul 6 2004, 03:12 PM
If it's synthetic, use a clean container and re-use the oil.....if it's dino oil....it ain't expensive.
Filters are cheap.....too.
Why did you use a sealant? If it was OK before....clean it up and make sure the gland nut is tight.
Kerrys914
post Jul 6 2004, 05:14 PM
I used sealant before. Must have been just the right amount of sealant, time of day, temperature, lunar events, or (IMG:style_emoticons/default/sad.gif)
Cheers
Kerry
- Lo-Fi Version Time is now: 27th December 2024 - 03:01 AM
