Jug size |
Jug size |
ruddyboys |
Jul 8 2004, 01:16 PM
Hummel eigentümer Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Is the outside diameter of a bigbore 96mm jug the same as the stock diameter?
bondo |
Jul 8 2004, 01:18 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Aww, that's not what I was hoping this thread was about (IMG:style_emoticons/default/smile.gif)
seanery |
Jul 8 2004, 01:19 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
A 96mm will fit in place of a 2.0 liter's 94mm without machine work to head or case. A 1.7 or 1.8 has a different answer.
ruddyboys |
Jul 8 2004, 01:23 PM
OK so if I need to order seals for the head and block, I should ask for the 2 liter seals.
I have a 70 1.7 |
seanery |
Jul 8 2004, 01:43 PM
I'm learning this as I go but, No seals between heads and cylinders. You'll need your heads machined unless you are using 2.0 heads. I'm not sure if the 96s will fit the 1.7 case without machining. Others will chime in I'm sure.
74914LE |
Jul 8 2004, 01:53 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
You will need to have the heads milled out to fit the 96mm jugs. The case should work,
but it is a tight fit. I have done this twice. Both times I put the 1.8Ltr. Big Bore kit on a 1.7Ltr. case. With this set up, you get the thicker wall size on the cylinders, but the heads must be enlarged. 74914LE |
seanery |
Jul 8 2004, 02:12 PM
In my reading on the jug sizes, I've read a couple times that the 96s made for the 1.7s are junk (too thin) and that the 96s made for the 1.8 are the way to go on a 1.7 case. No experience, just passing on what I've read.
tat2dphreak |
Jul 8 2004, 02:20 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
Sean... with 1.8 Heads you should be ok too... 1.8 jugs have the same o.d as 2.0 and the heads do not need to be flycut IIRC...
on the 1.7 heads you will have to cut for 96mm cylinders... |
JWest |
Jul 8 2004, 02:24 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
All cases have the same spigot size.
1.7 head registers are smaller than 1.8/2.0, which are the same. Do not use the head seals - VW issued a bulletin to stop using them. |
ruddyboys |
Jul 8 2004, 03:04 PM
I have the 96mm installed already, I am getting an oil leak around the jug and case and I suspect blow by on the head. I want to put the seals in to try to stop these problems. I need to know if I should buy the 2.0 seals. Does any one know were I can get the seals? AA has lists just one size for about 6 bucks each.
Joe Ricard |
Jul 8 2004, 03:28 PM
Don't believe seas will fix this. However since you need to pulle the top end off the motor anyway have the cylinder lapped to the case and head. Then Apply the correct torque you will be fine. Little bit of orange/ copper permatex THIN LAYER at the case end. No more leaks.
markb |
Jul 8 2004, 04:04 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
QUOTE(bondo @ Jul 8 2004, 11:18 AM) Aww, that's not what I was hoping this thread was about (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) |
WoMBaT |
Jul 9 2004, 01:59 AM
Member Group: Members Posts: 69 Joined: 29-June 04 From: Fort Riley, Kansas Member No.: 2,272 |
QUOTE QUOTE (bondo @ Jul 8 2004, 11:18 AM) Aww, that's not what I was hoping this thread was about smile.gif agree.gif I say it's false advertising! Where's Johnny Cochran when you need him? -Dan |
Lo-Fi Version | Time is now: 27th December 2024 - 08:33 AM |
