KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
I am running a 009 because my 050 isn't throwing spark for some reason.
Anyway, I read the other day that timing at idle should be like 12 degrees. Is this correct? I think I am at 7 degrees and while it runs, it's not running well. I know that many of you dislike the 009, but it's what I have for now. I will give it the float test sometime in the future, I promise. TIA |
McMark |
Correct timing at idle or correct timing at full advance, which do you want, cause you can't have both. (IMG:style_emoticons/default/wink.gif)
Unless you open it up and change the limit inside. It's not hard, but a little tedious. |
KaptKaos |
Mark,
At Idle please. Thanks |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Mark, At Idle please. Thanks The point is that there is no correct timing at idle because the 009 distributor is such crap that they all have different ranges of advance. You need to set timing at total advance and live with what ever your 009 has at idle. Mark has previously reported total advance in 009's from 15 degrees to 25 degrees. If you don't know how much advance yours has, settitng timing at idle is just a guess at what the timing will be in RPM ranges that count. Jim |
KaptKaos |
Guess I should figure out what's wrong with the 050 then.....
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
Mark's right. I set 009s at full advance. It's an "on or off" arrangement.
009s are good for race cars, but for in-town driving, they create bog off idle. Add Webers to the mix and you've got a bog-off-idle recipe for bog perfection. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st July 2024 - 12:54 PM |
