Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
O.K. folks, here it is from start to finish:
First you must remove the seam sealer and body tar from the inside corner of the longs. Attached image(s) ![]() |
Trekkor |
It is very thick in the corners.
Trekkor |
notice the bead of seam sealer that must come out so the sheet metal can fit to the floor pan tight.
Trekkor |
another
Trekkor |
an air chisel works very well to remove the material
Trekkor |
the width of the chisel point using careful, short bursts will quickly break out the tar.
Trekkor |
tar out
Trekkor |
without removal of the seam sealer and tar the sheet metal panels will not fit properly.
Trekkor |
passenger side drops right in.
Trekkor |
driver side in. the area around the e-brake handle needs to be worked to fit the contour (IMG:style_emoticons/default/smash.gif)
Trekkor |
more (IMG:style_emoticons/default/smash.gif)
I like to grind the edges for a good bite with the welder Attached image(s) ![]() |
Trekkor |
the inside corners need to be bent and worked into place (IMG:style_emoticons/default/smash.gif)
Trekkor |
other side
Trekkor |
back piece in .
3 sided dry fitment. Make sure it fits tight before any welding begins. Attached image(s) ![]() |
Trekkor |
(IMG:style_emoticons/default/welder.gif)
put the weld in the hole and burn into the car's long. then back fill the holes and make good contact into the long sheetmetal. It takes practice. Use low voltage and fast wire speed. Attached image(s) ![]() |
Trekkor |
mask off the interior and windows so as not to damage them. Ask me how I know (IMG:style_emoticons/default/headbang.gif)
grind your work Attached image(s) ![]() |
jgiroux67 |
Guitar Shredder ![]() ![]() ![]() Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 ![]() |
What are the black ovals for that are on the passenger side long's? Are they for access to the heater hose or what?
Trekkor |
driver side and ground down
Trekkor |
back plate
Trekkor |
all three sides tied in (IMG:style_emoticons/default/welder.gif)
Lo-Fi Version | Time is now: 3rd April 2025 - 06:51 PM |
