ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,981 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
![]() The engine is a 1911 I built to run D-Jet injection, originally intended for a customer's car, but he abandoned his project and left everything to me several years ago. I was running it with Dual Delortos with SSI HE's and a Tangerine IV muffler. It was my cold weather engine. The purpose of the current project was to develop an inexpensive FI setup which accomodates my horizontal cooling system. Stock type plenum systems won't fit over the flat fan. Systems which use ITBs generally aren't inexpensive, and are better suited to larger displacement, higher performance engines. Over the years I've collected a good selection of DJet hardware, both 1.7 and 2.0, so that seemed like the best place to start. So far I've only spent about $100, that's counting the small assortment of overstock materials and scraps already on hand at CFR. The only new purchases were the two silicone intake boots which connect the intake duct to the TBs. ![]() The injection system is all 914 DJet: Two 1.7L throttle bodies are mounted on separate tubular plenums, fabricated from the flange end of stock 1.7 intake runners and throttle body mounts from stock 1.7 plenums. The injectors are from a 2.0. The MPS is an AA special 2 liter unit, purchased in 1994 for my ITB race car. The ECU is a '73 2 liter unit. The air filter box is a modified 2 liter unit with a cold air intake inside the left rear fender well. The AAR is from a 1.7L. There is no decel valve or cold start valve. There's a balance tube between the two plenums - with take-offs for the MPS and the AAR. The TPS is on one of the TBs. The distributor vacuum advance and retard are connected to one of the TBs. ![]() I've already driven the car with K&N air filters mounted directly on the TBs. It runs great, but was rather loud right behind my head. Based on my A/F monitor, the mixture is almost perfect already. It idles smoothly at 850 rpm. The range of the idle mixture knob on the ECU allows me to set the idle too rich, too lean, or just right. We had to make special idle adjustment screws for the TBs to make the bypass hole smaller than normal, since each TB only feeds two cylinders. ![]() The relay board was moved up and back to accomodate the airbox. The airbox will be powdercoated now that the installation is finalized. I have a little more hose and wiring cleanup to do, but the wiring harness is totally stock, just routed a little differently across the engine. We did the install initially without surround tin, but the engine runs hotter than I like when it sits in traffic. Adding the tin is tomorrow's project. |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,806 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
This is just totally badass!! (IMG:style_emoticons/default/aktion035.gif)
rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
Chris
Just curious -- do you see any advantages to using this system (modified FI and plenum) with a stock cooling system? |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
Heck I'd call that F-Jet ( Frankin Jet for the good Dr. Stein ) . You are one crafty fella, Chris . Keep the ideas comin . I see you using your 914 specific throttle pulley wheels there , looks fantastic!!!!! (IMG:style_emoticons/default/pray.gif)
Jack |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Twin turbos.......do it
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,928 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Do you think your flowing more air? I like the duel TB's
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,800 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Thats some cool stuff! It looks like you had some fun coming up with it.
Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
As my Great Aunt used to say, "That is slicker than a mare's d---."
ChrisFoley |
Chris Just curious -- do you see any advantages to using this system (modified FI and plenum) with a stock cooling system? I don't know. It probably has similar shortcomings wrt cam overlap and MAP signal. I do have another pair of plenums already made up using 2.0 intake runner flanges. (IMG:style_emoticons/default/idea.gif) QUOTE Heck I'd call that F-Jet ( Frankin Jet for the good Dr. Stein ) . (IMG:style_emoticons/default/biggrin.gif) Good thought. Genaro (my welder/fabricator/painter) already suggested the Frank N. Stein monster theme for halloween. The airbox will be powdercoated orange (hopefully today), just like the plenums. He's gonna polish the aluminum duct too. QUOTE Twin turbos.......do it (IMG:style_emoticons/default/beerchug.gif) Already thinking about it. Maybe next years project. I don't think the DJet can handle positive pressure, so a different FI system would be needed. Maybe 911 CIS. (IMG:style_emoticons/default/beer3.gif) QUOTE Do you think your flowing more air? I like the duel TB's I haven't had an opportunity to really open it up yet. It behaves perfectly at part throttle though. It certainly has the capacity to flow more air than a single 2.0 TB, so more displacement should not be a problem. And two 2 liter TBs is always an option. QUOTE Thats some cool stuff! It looks like you had some fun coming up with it. I've always been a daydreamer. (IMG:style_emoticons/default/yellowsleep[1].gif) Now I really enjoy turning my dreams into reality. (IMG:style_emoticons/default/w00t.gif) |
r_towle |
It can take about 7 psi from what I remember.
Stock. ASk Marty Schnieder (MSDS)...he used to make a kit, headers and all. He wont start up again...I have called and begged. Sold back in the 80's If I remember right, he said it would run a small amount of boost and it was a fairly small turbo he used. Give him a call cause I know you could pull off a new system....twin turbos (tiny ones) might be even cooler. Rich |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
ChrisFoley |
It can take about 7 psi from what I remember. Stock. Good to know. (IMG:style_emoticons/default/smile.gif) I don't think I would run more than about 3 psi with this engine at more than 8 to 1 CR. |
r_towle |
I always thought twin turbos (small ones) would be easier to design while retaining the heat exchangers.
You now have a design for the FI that can leverage a twin turbo setup... If you do a deep search here Marty posted the original ad for the kit...and it had numbers on it of PSI and porjected HP. It was not a huge leap but I think it was near 150hp for a bolt on modification. Rich |
ChrisFoley |
r_towle |
Chris check your CHT's temperture. I have a 4 channel monitor always hooked up in this car. Hopefully this weekend I'll get to drive some distance and collect good data. Porsche of Nashua car show on sunday.... Should be a nice day for a long drive.. Just about 2 hours from you...might be less on Sunday. Rich |
arvcube |
Member ![]() ![]() Group: Members Posts: 170 Joined: 25-September 07 From: poway, ca Member No.: 8,147 ![]() |
nice setup. i envisioned something real similar to this that i would like to do, either with the dual TBs or a single.
ChrisFoley |
Lo-Fi Version | Time is now: 24th April 2025 - 07:11 AM |
