LS6/914 |
Never leaves the shop member ![]() ![]() Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest ![]() |
I need a source for 914 lexan quarter windows in the doors. It will be a interior vent project for a 914/8 track car. All the HVAC ducting at the dash has been sealed (P.O.) At the track its blistering in the interior. Not that Iam complaining. There was a Ferrari 250GTO running also however the owner and his tech would not say who built thier lexan side windows (IMG:style_emoticons/default/laugh.gif) Thanks, Lar
Kerrys914 |
Dear, the parts I just sold paid for that part ;) ![]() ![]() ![]() Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 ![]() |
I have some extra sheets of LEXAN. I guess I could cut you some windows from a template.
I have never tried to make windows before so any tips would be helpful. Cheers Kerry |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
You can drape form them over the original if you want. Cut the pattern of what you need and then lay it over the original and use a heat gun to form it.
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Make your own windows, there is no need for heating and shaping the quarter window shapes. take your old window out, use it as pattern, then cut the lexan. The lexan will be flexible enough to follow the slight curve of the window
Heres one I made for my 911, 1/8 lexan, with a naca duct Attached image(s) ![]() |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
OK.. call me crazy.
Do you want to replace the vent window or the main roll up glass ?? B |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,555 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
For a track car, do you really need windows?
I removed my door glass recently, as the rules allow it and it is usually too effin' hot around here anyway. All the inner door stuff & glass saves a ton of weight! (IMG:style_emoticons/default/smilie_pokal.gif) |
jgiroux67 |
Guitar Shredder ![]() ![]() ![]() Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 ![]() |
QUOTE(TimT @ Jul 24 2004, 06:56 PM) Heres one I made for my 911, 1/8 lexan, with a naca duct Wher do you get a naca duct and how much is it? |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
cut all my windows from lexan except the windshield.
vent is from wicks. dr Attached image(s) ![]() |
TimT |
I like tose little aircraft vent!! does Wicks have an online presence? edit just found them (IMG:style_emoticons/default/biggrin.gif)
I bough my naca ducts from Butler, but you can also get them from Pegasus |
LS6/914 |
dr. & gang thank you for the input. The quarte window with the round vent should work well. Yes it gets incredibly hot in the cabin. Last weekend at Pacific Raceway PCA required the top on even with a full cage & harness. The v8 ran all day at 190, its the driver that overheated (IMG:style_emoticons/default/sawzall-smiley.gif) prompting more airflow. Lar
Scott Carlberg |
Porsche MOTORSPORTS ![]() ![]() ![]() Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 05:52 PM |
