Compression Issues |
deloreandude86 |
Oct 16 2011, 06:27 PM
Austin Burkhardt Group: Members Posts: 61 Joined: 18-August 10 From: Austonio, TX Member No.: 12,068 Region Association: South East States |
Alright guys, we've been working on this for a while now and I'm starting to wonder just what the hell. A few weeks ago I checked the compression getting readings like 36, 42, 46, etc. so we tore the engine down, honed the cylinders checked the valves, rings, gaskets and everthing else, put it all back together and we're still getting the same readings, given it does have a little more power than it did before, as far as compression goes, its the same. Now this engine is intresting because during the rebuild we found out that it was originally a 72 1.7L. However, the bore is 94mm? could this have an effect on compression? and if so are my readings close to what they should be? Also is there a special technique to doing a compression check on the 914 that differs from a standard engine?
Thanks |
nathansnathan |
Oct 16 2011, 07:03 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I'd try verifying the readings with another gauge.
flash914 |
Oct 16 2011, 07:08 PM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
Normaly it's 3 compression strokes for a full test. Are you only doing one? This I think allows the hose on the gauge to "bleed" Kind of like getting the air out of a brake system. The other thing I would question, would be your compression ratio.
If it has 94 mm slugs and a 1.7 crank. ??? Heads over cut to the point that to much chamber. Also cam timing could be off allowing the valves to shut late. Don't know just things to check. Flash (IMG:style_emoticons/default/driving.gif) |
VaccaRabite |
Oct 16 2011, 08:11 PM
En Garde! Group: Admin Posts: 13,616 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
When you do a compression test you need to make sure of a few things.
1) Valves must be set properly. 2) make sure the throttle is wide open. 3) the engine must be warm. 4) crank the engine until the tester does not go any higher. Don't worry so much about the number of cranks. If the valves are off, the engine is cold, o the throttle is closed - eash of these things could cause poor compression. My engine was a 1.7 that was turned into a 2056. The heads were cut to accept 2.0 cylinders, and those cylinders were cut to 96mm. My last compression test was 165psi. A properly built engine will have killer compression. Zach |
914Mels |
Oct 16 2011, 09:09 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Somethings not right with your testing. I would suspect a bad compression gauge, with compression under 50 pounds on all your cylinders, your engine wouldn't even start.
Cap'n Krusty |
Oct 16 2011, 09:37 PM
Normaly it's 3 compression strokes for a full test. Are you only doing one? This I think allows the hose on the gauge to "bleed" Kind of like getting the air out of a brake system. The other thing I would question, would be your compression ratio. If it has 94 mm slugs and a 1.7 crank. ??? Heads over cut to the point that to much chamber. Also cam timing could be off allowing the valves to shut late. Don't know just things to check. Flash (IMG:style_emoticons/default/driving.gif) Three? Try eight compression strokes, paying extra attention to the first two or three and the last two. This is done AFTER a valve adjustment and with the engine at normal operating temperature with all the spark plugs removed and the ignition disabled. The Cap'n |
somd914 |
Oct 17 2011, 03:44 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Somethings not right with your testing. I would suspect a bad compression gauge, with compression under 50 pounds on all your cylinders, your engine wouldn't even start. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 04:02 PM |
