porschefile2010 |
Member ![]() ![]() Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand ![]() |
The indicator light in my dash starts flashing continually at a faster than normal speed when I turn the key on and still goes when the engine is running. All the turn lights and emergency flasher work as they should. If I use the turn indicator the light indicates as it should but at normal speed.
I don'thave an owners manual so does anyone know if this is a warning of some sort? |
AndyB |
The Governor is watching me ![]() ![]() ![]() Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States ![]() |
Have you checked your bulbs both front and rear?
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) While you're in there and unless you've done it recently, make sure all of your bulb contacts and connectors are corrosion-free.
Good luck |
porschefile2010 |
Thanks. Yes all the lights front and rear work fine. So I presume the repeated flashing doesn't mean anything apart from maybe a faulty contact or relay?
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
It's not the brake indicator light, is it? Those have a tendency to flash if the master cylinder switch hasn't been reset, or when there is a fault in the parking brake circuit.
porschefile2010 |
No, From memory that's a red light in the left hand cluster. This is the direction indictor light in the centre dial/rev counter. I was hoping someone might have a manual where it might tell us if there is a problem when this flashes like this. I get the impression it's not sinister-just annoying
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
.....You're running out of gas??(IMG:style_emoticons/default/smoke.gif)
(IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:18 PM |
