hwgunner |
914 Parts @ Discount Prices 800.321.5432 ![]() ![]() ![]() Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None ![]() |
I have a 914 rotisserie for sale. It is one of the nicest i have seen. Both ends spin on 914 rear wheel bearings and one end has a round plate with about 25 holes and a spring loaded pin to hold the body in just about any position you want. Pick up only. Will be on display on Saturday 11/19/2011. Bring a truck. It will not fit in your 914. $250.00. I will have crappy pictures at the end of the day to post. (IMG:style_emoticons/default/beerchug.gif)
This first pic is of the side that does not have the rotating stop mechanism. You can see the 2 ends that attach to the rear bumper holes. ![]() |
xsurfer |
Member ![]() ![]() Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 ![]() |
I have a 914 rotisserie for sale. It is one of the nicest i have seen. Both ends spin on 914 rear wheel bearings and one end has a round plate with about 25 holes and a spring loaded pin to hold the body in just about any position you want. Pick up only. Will be on display on Saturday 11/19/2011. Bring a truck. It will not fit in your 914. $250.00. I will have crappy pictures at the end of the day to post. (IMG:style_emoticons/default/beerchug.gif) Please send pics to gene@eselger.com Let me know if I'm first in line. How big a truck? Gene |
hwgunner |
I have a 914 rotisserie for sale. It is one of the nicest i have seen. Both ends spin on 914 rear wheel bearings and one end has a round plate with about 25 holes and a spring loaded pin to hold the body in just about any position you want. Pick up only. Will be on display on Saturday 11/19/2011. Bring a truck. It will not fit in your 914. $250.00. I will have crappy pictures at the end of the day to post. (IMG:style_emoticons/default/beerchug.gif) Please send pics to gene@eselger.com Let me know if I'm first in line. How big a truck? Gene I will send some pictures tonight. As far as truck size, the ends of the rotisserie will fit in a small truck but are heavy, maybe 150-200 pounds each. The biggest problem though are the 2 long peices that connect each end. they are about 16+ feet long and are made from some stout square steel making them heavy also. a lumber rack would be best. Where are you located?? jonathan |
xsurfer |
I have a 914 rotisserie for sale. It is one of the nicest i have seen. Both ends spin on 914 rear wheel bearings and one end has a round plate with about 25 holes and a spring loaded pin to hold the body in just about any position you want. Pick up only. Will be on display on Saturday 11/19/2011. Bring a truck. It will not fit in your 914. $250.00. I will have crappy pictures at the end of the day to post. (IMG:style_emoticons/default/beerchug.gif) Please send pics to gene@eselger.com Let me know if I'm first in line. How big a truck? Gene I will send some pictures tonight. As far as truck size, the ends of the rotisserie will fit in a small truck but are heavy, maybe 150-200 pounds each. The biggest problem though are the 2 long peices that connect each end. they are about 16+ feet long and are made from some stout square steel making them heavy also. a lumber rack would be best. Where are you located?? jonathan I'm in Pasadena, CA. Actually a few miles closer. Do you know what the thing weighs total? Awaiting pictures. Is the height adjustable? I have a doctors appointment on Wed., Wife to the airport on Sat. Morning. Should be able to round trip in a day? Prefer no Friday traffic. When is best for you? |
hwgunner |
I have a 914 rotisserie for sale. It is one of the nicest i have seen. Both ends spin on 914 rear wheel bearings and one end has a round plate with about 25 holes and a spring loaded pin to hold the body in just about any position you want. Pick up only. Will be on display on Saturday 11/19/2011. Bring a truck. It will not fit in your 914. $250.00. I will have crappy pictures at the end of the day to post. (IMG:style_emoticons/default/beerchug.gif) Please send pics to gene@eselger.com Let me know if I'm first in line. How big a truck? Gene I will send some pictures tonight. As far as truck size, the ends of the rotisserie will fit in a small truck but are heavy, maybe 150-200 pounds each. The biggest problem though are the 2 long peices that connect each end. they are about 16+ feet long and are made from some stout square steel making them heavy also. a lumber rack would be best. Where are you located?? jonathan I'm in Pasadena, CA. Actually a few miles closer. Do you know what the thing weighs total? Awaiting pictures. Is the height adjustable? I have a doctors appointment on Wed., Wife to the airport on Sat. Morning. Should be able to round trip in a day? Prefer no Friday traffic. When is best for you? I am available any time you can come to get it. Weight is going to be between 400-500 pounds with everything I think. Biggest problem is the bulk of the 2 ends. I beleive it is height adjustable but I can not remember for sure. I will have to let you know after I go home tonight. jonathan hwgunner |
hwgunner |
This one shows the back side of the first shot. You can see that it is on a wheel bearing to help it spin.
Attached thumbnail(s) ![]() |
hwgunner |
This one shows the spinner mechanism. Spring loaded pin at the bottom of the wheel with the holes.
hwgunner |
This shows the "inside" of the wheel mechanism. You can see also that it is adjustable up and down about 16 inches. This picture the cross member is in the correct orientation while the cross member in the first picture has spun upside down.
hwgunner |
Not shown in any of the pictures are the long end to end connecting pieces.. They are 16+ feet long. There are also some braces that go from the front bumper attachment pieces to the top of the front upper strut mounts. Let me know if there are any other questions.
jonathan |
xsurfer |
Not shown in any of the pictures are the long end to end connecting pieces.. They are 16+ feet long. There are also some braces that go from the front bumper attachment pieces to the top of the front upper strut mounts. Let me know if there are any other questions. jonathan Thanks for the photos. Is the other vertical side identical the pictured? Bearing to turn it? Over engineered may be an understatement. What do the pieces that go to the struts accomplish? I don't get it. The over all length is 17' feet? Is the height adjustable with the one bolt shown? Does the device spin 360? Gene |
xsurfer |
I'll take it. How do you want payment? I left a message on your machine at work.
I need to work out transportation. Thanks Gene |
Lo-Fi Version | Time is now: 26th June 2024 - 02:35 AM |
