> 12" caliper, what options are there?
malcolm2
post Dec 13 2011, 08:53 PM
OK this might be a crazy question. (IMG:style_emoticons/default/blink.gif) But I am working on push-rod length. I don't want to go buy a $50 tool. HF has a crappy $10 one. Or finally wait 6 days for an auction to end and still loose.
What are my options? I have two 6" digital calipers. Is there a way to use them? (IMG:style_emoticons/default/biggrin.gif)
Replies(1 - 6)
a914622
post Dec 13 2011, 09:34 PM
The ones at harborfrieght are not to bad.
jcl
sixnotfour
post Dec 13 2011, 09:38 PM
Something like this basically. you don't care what the number is as long as you can compare each one to each other ,
http://www.wttool.com/index/page/product/p...ments+%28USA%29
tscrihfield
post Dec 13 2011, 09:39 PM
Drive Fast and Take Chances
QUOTE(malcolm2 @ Dec 13 2011, 09:53 PM) *
Actually yes! Max one of them out and tighten the set screw. 6 In not the full max, it usually travels farther.
Using the back of the calipers (usually for depth and step measurements). Place your push rod against the maxed out calipers face down and tape them in place. Then using the same style surface on the other calipers you can take a measurement and add 6 inches. I wish I wasn't in my warm house readying for bed otherwise I would photo this for you.
Hopefully you can get what I mean though...
underthetire
post Dec 13 2011, 09:48 PM
The harbor freight one would work, if you know how to read vernier calipers. They do take some practice. The digital ones are pretty good, but they are the 50 bucks you don't want to spend.. You could make a wood jig and use a 1" travel indicator if you in a pinch.
http://www.harborfreight.com/1-inch-travel...icator-623.html
malcolm2
post Dec 13 2011, 09:49 PM
QUOTE(tscrihfield @ Dec 13 2011, 09:39 PM) *
I think I have the visual, I will have to try it. But I am not working on this right now, so if you think about it you can add a picture when you get around to it.
thanks
malcolm2
post Dec 13 2011, 09:56 PM
QUOTE(underthetire @ Dec 13 2011, 09:48 PM) *
It's not really the $50, but the fact that I may never use the tool again. Maybe this forum needs a Loan-a-tool program.
I have not used one in a very long time, but it is like riding a bike....
Video link of how to read Vernier Calipers
- Lo-Fi Version Time is now: 26th December 2024 - 05:47 PM
