Stonepilot |
Newbie ![]() Group: Members Posts: 20 Joined: 6-December 11 From: Pensacola, Florida Member No.: 13,863 Region Association: South East States ![]() |
I did a seach but didnt find anything. Has anyone tried this? Thank you for any help
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
yes Honda did it (IMG:style_emoticons/default/poke.gif) I have thought about seeing if that setup could be adapted, but I'm not sure it's worth the effort. Just more noise and a possible vacuum would be created
BajaXJ92 |
Extended Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region ![]() |
Sounds like one more system to end up breaking. (IMG:style_emoticons/default/dry.gif)
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If you look at high end convertibles they have a rear windscreen that pops up. This is to stop the wind buffeting as the air rolls over from the windshield.
A 914 already has this permanently in place. As Scotty said the noise, mid-engine means the engine is less than a couple of feet from your head, add to that the fact it's aircooled. My bet is you'd have quite the ringing in your ears after a ride. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,521 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'd rather have the roll up nite blinds that were used for LeMans.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Pull your rear window out and drive the car around for a while. BTDT. Once. Bring ear plugs.
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,527 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
What I want is side vent windows. (IMG:style_emoticons/default/driving.gif)
Jesse |
Jesse ![]() ![]() Group: Members Posts: 149 Joined: 15-February 10 From: Mobile, AL, USA Member No.: 11,363 Region Association: South East States ![]() ![]() |
Dittto on the side vents
(IMG:style_emoticons/default/rolleyes.gif) |
McMark |
Pull your rear window out and drive the car around for a while. BTDT. Once. Bring ear plugs. (IMG:style_emoticons/default/agree.gif) Enough said. |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Geez, I thought this thread was about something totally different from the title... (IMG:style_emoticons/default/happy11.gif) |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
There is a fairly significant "hump" in the middle of the rear firewall.
I just covered it in carpet and painted the engine side last night. This would make it impossible for the rear window to roll down. Stu |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I drove around the block once with the rear window out of the car.
Once. That was more than enough. The shape of the firewall does not lend itself to a roll-down window. You would have to flatten out enough of the firewall to make a space for the window, which would either cut into the inlet for cooling air, or into the seat travel. A new backpad would be needed, of course. At a guess, you'd probably wind up losing at least 6" of seat travel, which would be quite uncomfortable for most of us. Add that to the very dubious benefits of having a REALLY LOUD engine right behind your head with zero sound insulation. No, not worth it at all. --DD |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
I drove around the block once with the rear window out of the car. Once. That was more than enough. The shape of the firewall does not lend itself to a roll-down window. You would have to flatten out enough of the firewall to make a space for the window, which would either cut into the inlet for cooling air, or into the seat travel. A new backpad would be needed, of course. At a guess, you'd probably wind up losing at least 6" of seat travel, which would be quite uncomfortable for most of us. Add that to the very dubious benefits of having a REALLY LOUD engine right behind your head with zero sound insulation. No, not worth it at all. --DD (IMG:style_emoticons/default/agree.gif) |
racerbvd |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None ![]() |
Corvettes had a pop-out window in the 70s, there was a reason they changed the design, and the engine wasn't even behind that one..
VegasRacer |
That's not why. (IMG:style_emoticons/default/slap.gif) A teener vents smoke very well with the window cracked. I want to direct more fresh air into the cabin to cool the driver in the summer heat. |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,446 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
+1 on the vent wing windows, they'd be awesome
Lo-Fi Version | Time is now: 1st July 2024 - 06:33 AM |
