simonr |
Member ![]() ![]() Group: Members Posts: 65 Joined: 11-July 10 From: Indianapolis Indiana Member No.: 11,925 Region Association: None ![]() |
Need to find some engine tin as my heat exchangers have been upgraded to the early 73 74 units . My 76 air vent engine tin wont fit . I like engine tin so please help me out. I only need the air vent tin that goes between the exchangers and the push rod tubes Thanks
914LIVE |
Newbie ![]() Group: Members Posts: 10 Joined: 29-June 10 From: Portland, Oregon. Member No.: 11,890 Region Association: None ![]() |
Need to find some engine tin as my heat exchangers have been upgraded to the early 73 74 units . My 76 air vent engine tin wont fit . I like engine tin so please help me out. I only need the air vent tin that goes between the exchangers and the push rod tubes Thanks ================================================= Good afternoon. Send me a picture/diagram of what you need. I know I have some. Thank you, TOMAS. ================================================= |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
Need to find some engine tin as my heat exchangers have been upgraded to the early 73 74 units . My 76 air vent engine tin wont fit . I like engine tin so please help me out. I only need the air vent tin that goes between the exchangers and the push rod tubes Thanks ================================================= Good afternoon. Send me a picture/diagram of what you need. I know I have some. Thank you, TOMAS. ================================================= I believe he needs #11 and #12. Attached image(s) ![]() |
simonr |
Thanks for the diagram Jerry very cool of you to post that for me!!!
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Sounds like you need the warm air guides.
If you do not have them you will need different J tubes, S branches. Cant remember if the 75-76 had the warm air elbows. If you do need any of those parts I have them. I am short on the warm air guides. I may have the flat one that goes on the passenger side. Bruce |
B2524 |
It's a sickness. ![]() ![]() Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California ![]() |
Sounds like you need the warm air guides. If you do not have them you will need different J tubes, S branches. Cant remember if the 75-76 had the warm air elbows. If you do need any of those parts I have them. I am short on the warm air guides. I may have the flat one that goes on the passenger side. Bruce Hey Bruce did you ship my Koni's and rear springs yet?! I have the warm air guides and j pipes if you need them. Cheers, Kent |
Lo-Fi Version | Time is now: 25th June 2024 - 06:24 PM |
