736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
Here's an example of what not to do. This guy came to me and said his wheels didnt fit right on his car and he has a vibration at higher speeds. He also said he did his own 5-lug conversion.
For those of you who dont have the right tools to do this dont do it. Also use quality parts too. The carnage is below. |
736conver |
Cheap wheel studs.....Looks like Bug Pack strikes again
Attached image(s) ![]() |
736conver |
These were then Hammer in.
736conver |
Heres his way of countersinking.
736conver |
He use a hand drill to make this. They werent straight and the holes were not milled right for the studs to sit flush. Here is the correct way to do it. Dont mind the piece of bearing still on the hub.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Come on... everyone is trying to save a buck or two... (IMG:style_emoticons/default/laugh.gif) It takes 5 minutes to do it right. It takes 5 hours to fix it when it is wrong.
[B] |
736conver |
Not only that, he's out the whole $2.95 or whatever he spent on studs. (IMG:style_emoticons/default/wink.gif)
Plus new bearings at $35 a pop. Didnt save a dime. Cost more in the long run. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
are the hubs really strong enuff for the studs to hold without any additional bossed or hub thickness? i had a set and they were way to thin to put studs on IMHO without any sort of backing/boss
Brad Roberts |
This is why I get BIG money for the early rear hubs with the raised bosses for 5 lug. It has both patterns cast into it. I stopped counting how many conversion cars have loose rear studs because of the thin material.
B |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
QUOTE(Brad Roberts @ Aug 29 2004, 01:01 PM) This is why I get BIG money for the early rear hubs with the raised bosses for 5 lug. It has both patterns cast into it. I stopped counting how many conversion cars have loose rear studs because of the thin material. B I figure I can sell my rear hubs and oil tank and get enuff to retire.....plan A. Plan B is work till I die...... |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Damn, my plan A is your plan B.... (IMG:style_emoticons/default/sad.gif)
Aaron Cox |
QUOTE(markb @ Aug 29 2004, 08:59 PM) Damn, my plan A is your plan B.... (IMG:style_emoticons/default/sad.gif) whats ur plan b? (IMG:style_emoticons/default/lol2.gif) play the lotto until your broke? (IMG:style_emoticons/default/biggrin.gif) |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
QUOTE(Brad Roberts @ Aug 29 2004, 05:01 PM) This is why I get BIG money for the early rear hubs with the raised bosses for 5 lug. It has both patterns cast into it. I stopped counting how many conversion cars have loose rear studs because of the thin material. Yup, I actually switched from the thin hubs to the early hubs with the raised bosses. Just piece of mind. dr Attached image(s) ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
What about...
1. Machine off all bosses on the late style hub to get a nice flat circle. 2. Get a ring made of steel that you can then weld onto the newly machined surface. 3. Drill your holes and install your lugs in your new 360 degree thick hub. Well? |
Brad Roberts |
30lbs of rotating mass... We actually had a set of those floating around the shop. They weigh a ton when you are done.
B |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Attached thumbnail(s) ![]() |
McMark |
Spoken like a racer. (IMG:style_emoticons/default/bootyshake.gif)
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Brad, Andy's showing off again. (hahahahaha) (IMG:style_emoticons/default/biggrin.gif)
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
QUOTE(Brad Roberts @ Aug 29 2004, 02:01 PM) This is why I get BIG money for the early rear hubs with the raised bosses for 5 lug. It has both patterns cast into it. I stopped counting how many conversion cars have loose rear studs because of the thin material. B For re-drilled (and studded?) early model hubs, how many places to the left of the decimal point are we talking about filling? Is installing converted 5 lug hubs a 'simple' (250 ft/lb) bolt on? If so, then I wouldn't need to source new stub axles, rotors, and calipers or worry about the parking brake issue either. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:09 AM |
