Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
UPDATED 2/25/05
My $500.00 1975 2.0 I will be posting pics of my progress as I clean up this engine and put it in my '71 that currently has the stock 1.7L. Engine was running when it came out of the '75 about 3 years ago. About 10,000 miles on rebuild before it came out of the car, according to PO. No plans at this point to tear it completely down or do anything special (or costly). Just clean it up and replace/repair whatever is necessary. I welcome in comments/suggestions/opions that anyone wants to throw my way. (IMG:style_emoticons/default/smile.gif) Hopefully by next summer my I'll be driving my new toy. (IMG:style_emoticons/default/driving.gif) Time to get greasy! Sean Attached image(s) ![]() |
SpecialK |
aircraft surgeon ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 ![]() ![]() |
Looks very complete! (IMG:style_emoticons/default/smilie_pokal.gif) And the MPS looks brand new (or at the very least "less dirty" (IMG:style_emoticons/default/wink.gif) ) I'd scrap and replace all hoses and vacuum lines, including the intake runner boots, just to be on the safe side.
Be careful, it's very easy to say "Well hell, I've got it this far apart...I might as well...", and the next thing you (your wallet) know(s) you're doing a complete rebuild. |
Rhodes71/914 |
QUOTE(Special_K @ Sep 5 2004, 10:25 AM) Be careful, it's very easy to say "Well hell, I've got it this far apart...I might as well...", and the next thing you (your wallet) know(s) you're doing a complete rebuild. I am going to have to try really hard to keep myself from doing that. |
Mike9142.0 |
Member ![]() ![]() Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region ![]() |
Pull all the tin and clean all the crap off the cyilnders and oil cooler.
Take the alternator off and have it tested before the engine is in the car. |
Rhodes71/914 |
Progress from tonight, this thing has been sitting a while that's for sure.
Rhodes71/914 |
Not Sure what to think about this?
Rhodes71/914 |
One more-
Can anybody tell me why someone would do this? (IMG:style_emoticons/default/unsure.gif) Attached image(s) ![]() |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
Is it an old style starter disable for an alarm system?
dr |
Mike9142.0 |
Look's like the round fuel pump relay went out and was relaced with a more common relay.
porschefool |
Member ![]() ![]() Group: Members Posts: 82 Joined: 1-May 04 From: Monroe, WA Member No.: 2,010 ![]() |
Yep, That's it. Mine went dead on me, had to wire in a jumper to get the fuel pump running. I'm planning on doing a proper fix during the winter down time, but for now, flip the switch and drive!!
:finger2: Good luck with the 2.0. I'll be interested in watching your results... |
Rhodes71/914 |
Didn't get much done this weekend but here it is...
Everything has come apart easy so far. Attached image(s) ![]() |
Rhodes71/914 |
These will be nice once I get them cleaned up.
Anybody have a good way to get these clean. Attached image(s) ![]() |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
castrol super cleaner...the purple stuff...can't remember the exact name
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,642 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Rhodes,
if you can find a set of 73/74 heat exchangers and back date, you will pick up 5hp.... (I know its a "while your there, kinda thing" brant |
Rhodes71/914 |
QUOTE(brant @ Sep 7 2004, 07:12 AM) if you can find a set of 73/74 heat exchangers and back date, you will pick up 5hp.... What do you mean by "back date" Will the 73/74 fit without any mods? What causes it to have more hp? Thanks I appreciate the input. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
QUOTE(brant @ Sep 7 2004, 08:12 AM) Rhodes, if you can find a set of 73/74 heat exchangers and back date, you will pick up 5hp.... (I know its a "while your there, kinda thing" brant (IMG:style_emoticons/default/agree.gif) If you can't find the set he is talking about, use the entire system off your 1.7. It will flow better than the smog setup. The '75-"76 set up was a two cylinder into one pipe and is restrictive, especially when combined with the cat converter. It appears that the air injection holes in the heads are already plugged off, so the PO must have removed the smog pump and associated tubing already. You will like the 2.0 (IMG:style_emoticons/default/biggrin.gif) |
SpecialK |
Oven cleaner worked great on my heat exchangers (WEAR GLOVES!...duh). Let it set on there per instructions, and scrub them with a scotchbrite pad. A wire brush will work also, but you have to be very careful not to flip the oven cleaner on you while you're scrubbing.
And "while you've got it apart this far" (IMG:style_emoticons/default/wink.gif) take a large bastard file and "square" the tops of the exhaust inlets. It'll make for a better seal when re-installed. |
brant |
QUOTE(Rhodes71/914 @ Sep 7 2004, 08:51 AM) QUOTE(brant @ Sep 7 2004, 07:12 AM) if you can find a set of 73/74 heat exchangers and back date, you will pick up 5hp.... What do you mean by "back date" Will the 73/74 fit without any mods? What causes it to have more hp? Thanks I appreciate the input. Sean, (sorry for not paying attention and using your name correctly before) The 75/76 style is pretty restrictive.. I meant by back dating that yes, you can bolt up the complete early style system.... You can find SSI's or even stock 2.0 stuff will work well. I think you will need the all the bits... - a pair of Heat exchangers - I think the early style muffler (or bursch or any aftermarket for an early style 2.0) - an early style 2.0 muffler bracket (or you can make your own) - the muffler gaskets for the early style system. brant |
Rhodes71/914 |
QUOTE(SLITS @ Sep 7 2004, 07:54 AM) (IMG:style_emoticons/default/agree.gif) If you can't find the set he is talking about, use the entire system off your 1.7. It will flow better than the smog setup. The '75-"76 set up was a two cylinder into one pipe and is restrictive, especially when combined with the cat converter. It appears that the air injection holes in the heads are already plugged off, so the PO must have removed the smog pump and associated tubing already. You will like the 2.0 (IMG:style_emoticons/default/biggrin.gif) If I can use the system off of my 1.7L I will do that for now. Will it bolt on like it is? I was definitely going to go with a different muffler set up but if I can use the 1.7 then I will do that. Yes the injection holes were plugged, smog pump was taken off at some point. Another question - the oil filter is touching were the heat exchanger bolts to the exhaust coming out of the passanger side head. Is this normal? Maybe the filter is larger than it should be. Doesn't look like anything is tweaked. |
seanery |
yup, it'll bolt on directly.
Lo-Fi Version | Time is now: 23rd June 2024 - 12:51 PM |
