Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
1975-76 catalitic converter relay and harness. $20 plus 6.35 shipping USPS priority mail.
Attached thumbnail(s) ![]() |
914runnow |
Member ![]() ![]() Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None ![]() |
Sold..Payment to???
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
the box in the PAX foot well is a mile counter. the speedo cable goes thru it. it triggers the EGR service light every 30,000 miles
The sensor which controls the catalytic converter temperature is bolted directly to the catalytic converter and is connected to this relay, which is located next to the left taillight housing. |
sean_v8_914 |
this also triggers the CAT high temp warning light next to the tach
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,186 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
the box in the PAX foot well is a mile counter. the speedo cable goes thru it. it triggers the EGR service light every 30,000 miles The sensor which controls the catalytic converter temperature is bolted directly to the catalytic converter and is connected to this relay, which is located next to the left taillight housing. Hmmm Ive never seen this ... do you have a pic of a installed setup? |
zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
The sensor which controls the catalytic converter temperature is bolted directly to the catalytic converter and is connected to this relay, which is located next to the left taillight housing. Doesn't control, just measures. The sensors are usually burned up, I've been unsuccessful finding a replacement. |
914work |
Member ![]() ![]() Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None ![]() |
So it attaches here?
Attached image(s) ![]() |
sean_v8_914 |
that paragraph is cut and paste from factory manual so if its wrong, talk to wofgang or Hans
sean_v8_914 |
the sensor goes in teh cat where your plug cap is. the relay lives in teh rear trunk under teh left tail light biased toward the center. the sensor completed the relay circuit to trigger teh light on the dash next to the tach. I tried to paste a pic...
sean_v8_914 |
the sensor is a bi-metallic switch. Mc Master Carr has them. the question is: what temperature do we need to complete the circuit to trigger teh relay? at what temp is a CAT too hot?
914work |
So that port is on the muffler section on the inlet side of the CAT, not on the CAT itself.
The Port for the EGR feed pipe is on the Outlet side just before the final section & tailpipe. From what I understand shouldn't excessive cat temps be measured at the output, which would indicate too much un-burned hydrocarbons? |
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
Sweet. Always wondered what that was on my 75
914werke |
Hey Admins, perhaps this should be moved to the Garage since it has turned into a more informational/discussion thread than an classified ad?
If thats OK with the Geezer? |
914runnow |
Sold..Payment to??? Hi there...still awaiting info for payment to?? (IMG:style_emoticons/default/confused24.gif) Thanx Rx |
sean_v8_914 |
if it moves, Ill take pics
914werke |
Doesn't control, just measures. The sensors are usually burned up, I've been unsuccessful finding a replacement. They are available new link |
zonedoubt |
(IMG:style_emoticons/default/idea.gif) Hmmm...must be a new product for them.
914runnow |
Sold..Payment to??? Hi There..would still love to get this.. Thanx Rx (IMG:style_emoticons/default/piratenanner.gif) |
Geezer914 |
914runnow sent you a PM.
Lo-Fi Version | Time is now: 25th June 2024 - 12:04 AM |
