nynone4 |
Hammer to fit. Paint to match. ![]() ![]() Group: Members Posts: 353 Joined: 20-May 03 From: East Peoria, Illinois Member No.: 713 Region Association: None ![]() |
I'm getting ready to set up an appointment to have the 914-6 aligned. What specs should I be running for autocross and occasional street driving? Any racers out there want to share the measurements you're using to go fast?
Thanks! |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
I run as much camber as I can get, as much castor, front toe, 0 deg to a touch of toe out. rear toe about 1/16th toe in... at least thats what I have in the car now
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
1.5 to 2 degrees of Negative Camber front & rear, or as negative as you can and still get reasonable tire ware for street use.
Front Toe close to 0, rear 0 to 15' toe-in. Be sure the F & R Toes are equal on both sides. Ken |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
If my car is any indicator, you'll not get more than about 1 deg negative camber up front......and that's with the car lowered about as far as the shock travel will permit. Some tires like the 2 deg negative (or so). Rspec Kuhmos and Hoosiers certainly do and that is what this is all about.....what the tires like. |
jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I have heard before to run half a degree less camber up front than in the rear, any one agree with this?
Or can you run as much neg camber in the front as you can and set the rear so you still have clearance between the inside of the tire and fender well? |
J P Stein |
QUOTE(jmargush @ Sep 8 2004, 06:18 AM) I have heard before to run half a degree less camber up front than in the rear, any one agree with this? Or can you run as much neg camber in the front as you can and set the rear so you still have clearance between the inside of the tire and fender well? You're into suspension tuning here. IMO, there are no hard & fast rules.....just some general WAGs to get you in the ball park. Alignment is dependent on your spring/shock/tire/usage.....yada. 2 deg negative is gonna wear out the inside tires edge on a street car in short order. AXers don't care cause they'll be lucky to get a season out of their stickeybuns. (IMG:style_emoticons/default/biggrin.gif) More or less camber front to rear depends on what the tire temps say......with a few wild cards thrown in. For instance: The insides of my rear tires are hotter than the outsides.... a *bit* of wheel spin accounts for that....*I think*. The fronts are even across but not as hot as the rears. I'm STILL working on tire pressures in an attempt to get more heat into the fronts. Dropping the fronts pressure causes more heat but turn in suffers till the heat comes in.....and sometimes the heat doesn't come. (IMG:style_emoticons/default/confused24.gif) Toe. 0 toe in the rear is fine for a AXer. Take it to the track and you may discover (as I did) "rear steer". (IMG:style_emoticons/default/w00t.gif) Stock front and rear toe is best for a street car.....usless you drive on extra wide lanes. What I do to my AX only rig does not translate to a casual AXer/street driven car. How much do you want to compromise you street driven car to be an AX hero? |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
QUOTE(J P Stein @ Sep 8 2004, 07:50 AM) What I do to my AX only rig does not translate to a casual AXer/street driven car. How much do you want to compromise you street driven car to be an AX hero? Thank you, JP My car will always be streetable. I have yet to get that "competition allignment" I "need". KT |
J P Stein |
QUOTE(trekkor @ Sep 8 2004, 07:02 AM) Thank you, JP My car will always be streetable. KT Wanna bet? (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 11:24 PM |
