> starting issues, having problems running
pose
post Sep 7 2004, 06:22 PM
hi,
im a newbie so please excuse the beginner's questions.
I have a 1975 1.8L L-jet. Currently the car will start, but not idle at all. I checked all the vaccuum lines in back and cant find anything wrong with them. The car reads as having between and quater and half of a tank of guess, which i put in.
I just replaced the battery and i can hear the feul pump humming when I turn the car on.
I am baffeled as to what the heck is going on, any help would be appreciated.
Thanks.
Replies(1 - 9)
Brad Roberts
post Sep 7 2004, 07:40 PM
914 Freak!
Welcome (IMG:style_emoticons/default/clap56.gif) I dont know a damn thing about the 1.8 injection, but I'm betting someone on here does (I lied.. I have a clue but I dont know enough to help out unless the car is in front of me)
Mueller ??
B
post Sep 7 2004, 07:50 PM
Resident German
CHT? Vaccuum leak? TPS?
i'm just guessing here ...
(IMG:style_emoticons/default/confused24.gif) Andy
Brad Roberts
post Sep 7 2004, 08:10 PM
914 Freak!
Yep. one vacuum line off and they die pretty easy.
B
pose
post Sep 7 2004, 08:21 PM
any advice on a good way to check for vaccuum leaks because I think ive dont a good job, but have found none.
thanks again
post Sep 7 2004, 08:25 PM
Resident German
QUOTE(pose @ Sep 7 2004, 07:21 PM)
i'd say spray some carb cleaner on the hoses and TB and filler cap, but if the car isn't ideling, that's not going to be easy (IMG:style_emoticons/default/wink.gif)
does it run if you hold the throttle open by hand?
(IMG:style_emoticons/default/idea.gif) Andy
Brad Roberts
post Sep 7 2004, 08:27 PM
914 Freak!
Very important that the oil cap be 100% sealed. If you just added oil and it didnt run after that.....
B
Trekkor
post Sep 7 2004, 11:13 PM
I do things...
I had the same set-up years ago 75 1.8 l-jet. Didn't like it.
Always had problems. Went through everything. Ran good, sometimes. Wouldn't pass smog. Sold it.
Anyway, check the position of the flapper in the air flow meter ( potentiometer? name? ). If it stays shut while cranking it will start on cold start injector only and then die.
Make sure that flapper is able to move freely. There is a plastic lid on top of the AFM that lets you fake the brain out if you open it up. You may need an assistant to help you.
I have a spare one here, if you want to try it. Brain, too.
KT
pose
post Sep 8 2004, 04:17 PM
spare assistant and brain? do i understand you correctly?
Trekkor
post Sep 8 2004, 05:11 PM
I do things...
QUOTE(pose @ Sep 8 2004, 03:17 PM)
(IMG:style_emoticons/default/lol2.gif) Sort of.
I have a spare AFM ( air flow meter ) and brain ( 1.8 l-jet specific computer controller ).
I'm offering to loan them to you.
Not my assistant and my brain, as I am currently using them both. (IMG:style_emoticons/default/unsure.gif)
KT
- Lo-Fi Version Time is now: 22nd December 2024 - 05:53 AM
