Cutting spot welds, gotta start somewhere :) |
bryanthompson |
Sep 12 2004, 08:21 AM
Check it out... 3 loops! Group: Members Posts: 208 Joined: 23-April 04 From: elwood, ne Member No.: 1,970 |
I started on my 914 project and decided to do the trunk first. So, i started chipping away bondo from the inside of the bottom of the trunk and found (suprise!) more rust than expected. So, the bottom part of my trunk pan has to be replaced.
Anyway, i bought a spot weld cutter yesterday, but something about it makes me wonder. The tool looks just like this: (IMG:http://www.ingallseng.com/graphics/Prodcut_Pictures/92900.jpg) So, should i trim down the spikey thing or let it go through the whole car? I realize i'll be welding it back up so it wouldn't be the worst thing in the world if it made a hole, but what i'm worried about is the bending effect putting that much force will have... like i'll end up with little pimples around the hole left by the spike (not the saw part). (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/monkeydance.gif) |
Slowpoke |
Sep 12 2004, 08:49 AM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
Those tools are handy. I just drill a hole in the panel the size of the spike coming out of it. This gives me better control of the cutting and a small 1/8 hole is easy to mig close on the piece I'm trying to save. But, you do have to be carefull not to cut all the way thru both pieces of metal. Because, you are defeating the purpose of the stop feature (that's why the spike it there, you adjust the stop from the other end of the tool). I also have luck just drilling with a drill bit the spot weld itself. All it takes is patience either way.
bryanthompson |
Sep 12 2004, 08:55 AM
Ohh, i see now! I didn't even notice the hole on the other end of the tool was shaped like an allen head. well, shoot, i'm gonna go play now! Thanks man. (IMG:style_emoticons/default/beerchug.gif)
Bleyseng |
Sep 12 2004, 09:41 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Just go slow and don't push too hard so that the bit does the work by cutting only thru the top layer of the panels. I use a drill set first to then locate the spot weld cutting bit so it doesn't wander all over the place. Geoff |
kafermeister |
Sep 12 2004, 12:06 PM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
Hmmm. I've got one of those and the spikey part in the middle is spring-loaded. No need to drill a hole. Mine wonders all over the place even with a pilot divot. I think the one you have may be better than mine. Hope yours works better.
Rick |
bryanthompson |
Sep 12 2004, 01:05 PM
QUOTE Just go slow and don't push too hard so that the bit does the work by cutting only thru the top layer of the panels. after some practice, i got it... but I went through a couple times. Will be good practice in fixing holes in sheet metal though. And, it turns out the center was spring loaded, so I drilled a small hole in the middle of the weld, not all the way through, just tapped the surface. Anyhow, going slow it seemed to work fine. Once i get it all looking decent i'll take pics... looks sortof crappy right now. |
qa1142 |
Sep 12 2004, 03:20 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
If you work slowly, you can just pop the spot welds with an air chisel. Way faster than drilling every weld, just make sure is you sacrifice metal it is the piece you are replacing. I had rest pf battery tray out in (IMG:style_emoticons/default/sawzall-smiley.gif)
Lo-Fi Version | Time is now: 27th December 2024 - 09:38 AM |
